Old March 12, 2008, 05:31 PM
3.0charlie's Avatar
Just to let you know that I just tried the "Legion Hardware" overclock setup and Prime fails at 480 MHz FSB. That "tutorial" is flawed and unstable. I used my 3rd rig, the one with the E8400.
Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182
HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B
Old March 12, 2008, 10:13 PM
mmm ok... so what overclocking i have to use?.. what guide?
Old March 13, 2008, 05:29 AM
3.0charlie's Avatar
There is no "true" guide to oc'ing. You have to learn and understand what are the effects of every BIOS setting. Start by reading the reviews of your board and some sites may also show some oc'ing setups. Remember that the hardwar used will have an impact on your oc, and that no 2 same hardware setups oc the to the same level.
E8400 Anywhere? BladeRunnerFan Hot Deals 12 March 25, 2008 12:50 PM
For those who want an E8400 Cptn Vortex CPU's and Motherboards 69 March 11, 2008 10:03 PM
WTB: E8400 3.0 Ghz darksniperx Buy/Sell & Trade 0 March 6, 2008 06:18 AM
E8400 @ ncix omgwtf CPU's and Motherboards 8 February 17, 2008 12:17 PM
E8400 for $209.99 Shadowmeph Hot Deals 5 January 30, 2008 07:44 AM
