-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   help me get to 4ghz on my C0! (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/50015-help-me-get-4ghz-my-c0.html)
geoc January 3, 2012 01:50 AM
I have been trying my best to learn how to overclock the past the bloomfield last few days, and I've only managed to get an overclock of 3.7ghz w/ HT stable.
No matter how much voltage I dump, it just wouldn't hit 4ghz.
Here are my current settings:
bclk 195
multi 19
QPI 3510
RAM 780 9-9-9-24 (running 6x4gb sticks)
the voltage settings right now are:
voltage 1.25v
VTT auto
LLC/no vdroop on
dram 1.654v
PLL auto
I have tried all settings from PLL to 1.88v and VTT to 1.28v and vcore at 1.3v and it still wouldn't hold 190x21.
stoanee January 3, 2012 06:38 AM
Probably hit your limit....................
geoc January 3, 2012 10:30 AM
:sad: , kinda expected more from the chip. Oh well...
stoanee January 3, 2012 10:33 AM
The DO was usually the better chip.
cable January 19, 2012 05:48 PM
i have my i7 920 C0 running stable at 3.8 in a asus p6t board
stoanee January 19, 2012 06:16 PM
have a look at this guide:
Guide to Overclocking the Core I7 920 or 930 to 4.0ghz
zsamz_ January 19, 2012 06:57 PM
i had a C0 that did only 4.4 so i sold it a loooong time ago
for 4.0
cpu 1.35-1.44v
vtt 1.3-1.42v you got 6 stix:whistle:
pll 1.7-1.84v
Fudd Rucker January 20, 2012 11:07 AM
My C0 would only do 3.6ghz and even then it was flaky. Got rid of that, got a D0 and good times had by all.
dandelioneater January 20, 2012 12:10 PM
Can you not hit it with a bit more vcore? The max safe vcore according to intel is 1.4 isn't it?
geoc January 21, 2012 11:06 AM
i tried 1.4v vcore, it the computer just shuts off and restarts 5 seconds into prime95... My psu is rated at 800w, so I assume that wouldn't be the problem.
