Old December 29, 2011, 07:59 AM
Default i7 2600k overclocked temp question
I've overclocked my CPU by using ASUS TurboV EVO Auto Tuning Fast Mode. The details are below:
Frequency: 4429MHz (103.02 x 43)
Voltage: 1.32v (when load)
idle temp: 30-35C
load temp (intel burn test): 70C-72C max depends on ambient temp
ambient temp: 23~25C
I've did some research on that and others are getting less than 60C~65C when load at 4.4GHz but in my case my CPU has already hit the 70C+.
Has anyone else has the similar case to mine? or I just got a bad chip? =(
Old December 29, 2011, 08:47 AM
gingerbee's Avatar
it could just be a difference in heatsinks used
Old December 29, 2011, 08:59 AM
G777's Avatar
In my experience the Asus software will tend to use higher values (Vcore, LLC, Vdram etc) than what would be achievable manually overclocking, thus giving you higher temps in comparison.
_______________________________________________
HWC Overclocking Team, breaking hardware for fun!
Team Thread
Old December 29, 2011, 09:09 AM
Adzsask's Avatar
Do a manual OC and lower those voltages, also spend $30 on a hyper 212+ and then you will never have to worry about temps again.
Old December 29, 2011, 07:12 PM
i've done manual overclocking
frequency: 4.6ghz
voltage 1.315v
and my load temp (prime35) easily hit 70C~72C while I see others are around 65C. my spec is under 'my spec'
any ideas?
Old December 29, 2011, 07:30 PM
gingerbee's Avatar
ya the noctua does not do a bad job whats you ambient room temps ( mine are always higher cause i keep my apt at 25c and up )
Old December 29, 2011, 08:14 PM
canada2005's Avatar
Nothing wrong with that overclock at all.
Old December 30, 2011, 08:04 AM
I am running at 4.7ghz/1.35v current and going to test the stability later.
I've ran a short intel burn test and the result i got is
load temp: 71C
ambient temp: 25C
is that normal?
Old December 30, 2011, 08:47 AM
I don't think its abnormal, especially with that ambient, are you cooking a turkey? Nevermind just realized your in Malaysia. LOL. It 1 degree here and my house barely hits 20C
Old December 30, 2011, 10:39 AM
gingerbee's Avatar
those temps are great nothing to worry about
Overclocked System Build With 2600K - Thinking about Liquid Cooling Linus LinusTechTips Q&A 5 September 28, 2011 08:30 PM
2600k overclocking question's kyle_L Overclocking, Tweaking and Benchmarking 1 August 12, 2011 04:34 AM
6970 temp question ultraman7k Video Cards 5 May 23, 2011 10:49 AM
What's a safe load temp for an overclocked GPU? chouchou Video Cards 19 December 29, 2008 11:21 AM
another cpu temp question madness69 Troubleshooting 3 April 4, 2008 06:48 PM
