Old March 8, 2008, 11:01 AM
Question Overclocking my BFG8800GT
Hey Guys I'm new here and what better place to turn then here for this question. I recently bought a 8800gt installed the artic cooler s1 and frankensteined some fans on it to provide cool air aswell as exhaus the hot fins. My question is I began OC with ati tool to test for artifcats and rivatuner to adjust the clocks and monitor my temps. WIth a case temp of around 33-39, I was Oc and not getting any temps on my card above 57 degrees. My question is, I was getting snowflakes as soon as my temperature hit 57 degrees, so right now im stuck with a clock around 750 which would be fine with a stock cooler but I got a big beefy one and my temps are friggin low being only 57? Any suggestions. THanx
Old March 8, 2008, 12:48 PM
3.0charlie's Avatar
First, welcome! Second, did you add any heatsinks to the Ram chips?
Old March 8, 2008, 02:00 PM
Yep the accelero comes with them so I put them on every heatsink, I also havn't started touching the ram clock, I did reapply some thermal and reput on the cooler and it seems to idle at 36 steady now, so I will try and oc tonite and see if it will stay lower.
Old March 8, 2008, 02:25 PM
3.0charlie's Avatar
Don't forget to unlink the Shaders from the core clock when oc'ing.
Old March 8, 2008, 02:51 PM
I have them unlinked. I have the clock up to 760 now running smooth for 10 minutes no artifacts or errors but bump it to 765 adn they appear immediatly. Its also weird because my card is running at only 54 degrees when this happens, does temp only cause the artifacts or errors or could it be my coltage I see many people have done the voltage mod, but i got no floppy LOL
Old March 8, 2008, 05:40 PM
3.0charlie's Avatar
Not 2 cards (and not 2 CPUs) oc the same... did you raise the PCI-e volts in the BIOS?
Old March 8, 2008, 10:29 PM
NO i havn't because I dont' have a floppy, i was going to try and find another method.
Old March 9, 2008, 07:45 AM
3.0charlie's Avatar
You don't need a floppy to raise the PCI-e volts in the BIOS...
Old March 9, 2008, 09:38 AM
Could you link a guide that shows me how then if you can, if not after work ill have a look around on the net!
Old March 9, 2008, 11:07 AM
yycraven's Avatar
what mobo you using, I have a BFG 8800GT OC, and get good OCing on it. but of course depends on mobo, to tell you how to get into it.
for my Asus P5K I just press the delete button and get into BOIS that way.
ASRock Extreme 3,2500K,NH-D14,Patriot G2 16GB ,WD 750GB,640GB Sata ,2 GTX 470 SLi Thermaltake toughpower XT850W,Tech Station. V243H,2253LW LCD
heatware
Overclocking 2900XT Varroa Video Cards 1 February 25, 2008 05:27 PM
Overclocking help tzetsin Overclocking, Tweaking and Benchmarking 41 January 27, 2008 11:05 PM
Overclocking P4 1.8 Kassela Overclocking, Tweaking and Benchmarking 1 December 27, 2007 11:28 AM
Need help overclocking further Kessler Overclocking, Tweaking and Benchmarking 15 December 5, 2007 05:09 PM
Need some help on Overclocking ShinseiKen CPU's and Motherboards 10 July 11, 2007 07:41 PM
