-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   i5-2500K Max Gflops (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/49523-i5-2500k-max-gflops.html)
Zer0 December 17, 2011 11:51 PM
i5-2500K Max Gflops
Just ran LinX with my new setup and got 123.45Gflops with a 4.5Ghz OC. What are your max Gflops with this chip?
2500K @ 4.5Ghz (1.284V with Level 7 LLC - Idle reads 1.296V)
Gigabyte Z68XP-UD5
Corsair Vengeance LP 1600Mhz 4GBx2 9-9-9-24
http://dl.dropbox.com/u/9284282/Pict...r/4.5_Linx.png
bissa December 18, 2011 12:04 AM
wow my upgrade is going to be awesome. I'm getting about 10 GFlops when I ran that with my E5200.
Zer0 December 18, 2011 12:11 AM
Yes, definitely a good upgrade. I'm coming from an E8400 @ 4.0Ghz and the 2500K blows it away. Keep in mind that the 123Gflops score is the result of the new AVX instruction set supported by the CPU. You'll need applications that support AVX to take full advantage of it. Without it, you'll get around half the Gflops.
