Old December 6, 2011, 06:31 AM
Default help for overclocking a 1055t
hi, i would like to overclock my 1055t to as high as possible with volts on auto. useing a GB 990fx-ud3 with 8gigs of 1333mhz ram.
has anyone done this?
is the boost on?
and is not changeing the volts just stupid?
im new with overclocking, so i dont want to mess with alot of stuff atm.
thanks
Old December 6, 2011, 02:18 PM
When using the AUTO function what is your vcore set to?
Your going to need to do disable all the power saving features in the BIOS
AMD Cool&Quiet / C1E / OC Stepping / AMD Turbo core / any OC gienie(MSi) or like / OC dial function(MSi) / Spread Spectrum
Your probably going to have to mess with the volts but the ultimate goal is finding the lowest stable voltage.
Here are my current settings, I will be going higher when my Hyper 212 EVO comes.
3.50GHz - 1.325V
250x14 / 250x9(2250MHz(1.2V)(HT 250x8-2000MHz) / RAM 250x6.67(1667MHz)
Old December 6, 2011, 06:35 PM
If you don't want to change anything, you're better off not doing it. Overclocking with voltage settings on auto is just asking for trouble.
Old December 6, 2011, 06:53 PM
on auto my vcore is at 1.4750V
and if i disabled all those stuff, will my idle speed be my max speed?
1055T vs 965 great_big_abyss CPU's and Motherboards 14 November 22, 2011 05:58 PM
890FXA-UD5 & 1055T Overclocking help appreciated :-) TerenceJ Overclocking, Tweaking and Benchmarking 14 November 9, 2011 05:31 PM
Help with 1055t cbr1100xx Overclocking, Tweaking and Benchmarking 12 October 28, 2010 02:35 PM
AMD 955 or 1055T? jcmaz CPU's and Motherboards 7 May 17, 2010 07:55 AM
