Old December 6, 2011, 04:47 PM
@all: running prime 95 for 9 hours and 30 mins...still going good...guess i am stable at 4.25 ghz... but still gonna let it run a few more hours to make sure...
thanks to everyone for making this possible...
Cheers!
Old December 6, 2011, 04:56 PM
guys... i got it running for 9 and a half hours in prime 95 without trouble...and unfortunately there was a powe fluctuation in me area and the pc restarted...do you think this is enough or should i run it for 12+ hours...?
Old December 12, 2011, 01:04 AM
Its up to the individual.
I may do an initial test for 12 hours but i always do 24 hours of prime 95 64 bit version to finish out.
Cambridge,ON
MSI Z77 M Power/Bios17.7
i5 3570k@4.5ghz
Mushkin #997007
Noctua NH-D14
EVGA GTX460
Seasonic X-660
Antec P280
Intel Speed Demon Equipped
using Prime 95 27.9
Old December 12, 2011, 12:50 PM
Default overclocking 980
need much more info then you are providing
need toknow what ram and the timings, also what voltage you are using for the ram
what unicore ur using plus qpi/vtt
actually go here
Need Help Overclocking UD9 / 980x to 4.2Ghz on Air.
there are many more setting then just cpu voltage to deal with
intel 980@4500mhz
gigabyte x58a-ud5
24 gig of gskill sniper 1600
triple and double rads
dual serial d5 pumps
3x27 in asus lcd
dual 6970's ek blocks
corsair 1000w
mm case
Old December 24, 2011, 06:53 PM
@flybye: yeah will give u the details in a while!
SLI issue's avrionis Troubleshooting 4 December 30, 2010 09:31 PM
...So it's not a PSU issue.... BrainEater Troubleshooting 3 March 19, 2010 12:55 PM
Odd issue with overclocking and CPU voltage Arundor Overclocking, Tweaking and Benchmarking 1 July 8, 2009 01:09 PM
Help!, PSU issue... xXxRithxXx Power Supplies 3 May 25, 2009 12:37 PM
Overclocking Issue? Corpus Masochist Troubleshooting 21 April 14, 2008 04:57 AM
