Old December 3, 2011, 12:47 PM
Default OC 955 BE with CCC need HELP
I was going to upgrade my CPU and MOBO in 2012 but until then I was trying to sqeeze out as much juice on my current rig. Im still learning how to do a manual OC, so I used CCC to do an auto OC. Can somebody look at this screen and tell me if the numbers look ok and or how I can do better and what to use. The highest OC I got was between 4.3-4.4 then my PC crashed, so I left it on a stable 4.0 ghz but i read my CPU could do better. My setup is
Asus M4A785-M
AMD 955x4 BE
Corsair H70
750 watt ultra LSP pro
8gb ram DDR2
AMD 6950 2gb
Old December 3, 2011, 01:47 PM
Supergrover's Avatar
Official Phenom and AM2/AM2+ Overclocking Guide
R.I.P.
