  #21 (permalink)
Old December 19, 2008, 10:32 PM
This is my most recent attempt.
Cooling is Liquid, mostly Swiftech parts.
DFI LP DK P45 T2RS Motherboard. 4 GB (2x2GB) Mushkin Ascent PC2-8000
E2160.
  #22 (permalink)
Old December 20, 2008, 08:07 AM
1.64 volts is pretty high. Does water cooling let you run that safely? Is it volts or heat that will kill a chip?
Your 12 volts line looks like it drooping quite a bit. But 3.6 is about as high as I have ever heard of e2160 running.
How high can you push an 8 times multi?
  #23 (permalink)
Old December 20, 2008, 08:15 AM
3.0charlie's Avatar
Congrats on over 100% OC, but volts do kill chips and boards, not high temps...
Hydro-Quebec is salivating...
  #24 (permalink)
Old December 20, 2008, 08:42 AM
1Tanker's Avatar
Very nice Wall86. Did you vCore-mod your DS3L? The highest vCore i can get is 1.6(1.54-1.568 real)..then the next step is 1.80.
This was my best with my daughter's chip. This was on air, in my basement(ambient 17c).
-E2160(TRUE/lotsa fans)
-GA P35-DS3L (no mods)
-2x1GB Ballistix 8500
-XP-Pro SP2
CPU-Z Validator 3.0
Wasn't very stable..due to dam vCore limitations(1.64 would have stabilized it easily).. temp was not an issue.
  #25 (permalink)
Old December 20, 2008, 03:39 PM
I should update my signature.
This is running on a DFI LP DK P45 T2RS.
If the board and CPU Die that just means I will have to upgrade. So it is a win-win situation. Might just urge me to go X48 with a decent CPU.
Super Pi results:
I really wanna see what an E7200 would do.
  #26 (permalink)
Old December 20, 2008, 05:24 PM
Silvgearx's Avatar
Wow those e2160 are champs.
  #27 (permalink)
Old June 9, 2009, 04:52 AM
Mr. Cipher's Avatar
All - should I bother updating the thread, now that it seems that we've moved onto the i7? I've been out of the loop since fall of '08 due to work so I would appreciate your feedback!
i7 Red
EVGA X58 Classy | i7 920 D0 | Megahalems w. 1 noctua push| Mushkin Redline | Radeon HD 6870 | 2x640 WD Black | Corsair HX1000 | HAF 932 | Asus 26" LCD
C2Q Blue
Gigabyte EP45-UD3p | Q8400 @ 2.66ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 400mhz |
BFG GTX 295 | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900 | Acer 20" LCD
  #28 (permalink)
Old June 9, 2009, 02:44 PM
I say yes,
With my newest re-build, I am debating bringing my E2160 out of retirement for a run with a Boreas, see what it can do with some real cooling.
  #29 (permalink)
Old August 7, 2009, 07:17 AM
hi,
uhh, 1.64 sounds *very high for me to...
ok watercooling, but anyway massive voltage for such a chip
