100%. Unless you stumbled across a very bad chip.
__________________ Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182 HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B |
| Good to know, thanks. :)
__________________ Intel Core 2 Quad Q6600 "G0" 2.4GHz Overclocked @ 3.61GHz Zalman CNPS9700 LED Cooler Master Real Power Pro 750watt PSU Asus Maximus Formula BIOS v1004 8GB OCZ PC2-6400 800MHz Vista Performance Platinum Edition @ 5-5-5-15 2T Dual Radeon 3870x2's (Stock for now) WD Raptor 74GB 10,000rpm SATA | WD 500GB 7200rpm SATA | WD 500GB 7200rpm SATA LG DVD-RW Dual Layer SATA Antech 900 Advance Gaming Case 42" LG LCD 1920x1080p | BenQ W5000 1080p LCD Projector 155" Windows Vista Ultimate x64 |
I have 3.2GHZ with the Q6600's little brother, the X3210, using 1.275V, and the stock cooler! You can EASILY get 3.2. I would personally be aiming for 3.6GHZ, probably need about 1.4V or a little more. The Maximus Loves quadcores!
__________________ The Vortex H20 Case....not sure what to call it DFI X38 LT Xeon X3210 @ 3.2GHZ 1.30V PNY 9800GX2 (750/2200) 4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V Ultra X3 1000W PSU HT Omega Striker 2x500GB Hitachi RAID 0, 250 Seagate Sharp 32" Aquos 1080p Benq W500 1080i Pojector. Watercooling: Loop 1 - D-Tek Fuzion Quad Nozzle Bowed, MCR320+Zalman ZM-F3 Fans, MCP655, MCRES Micro. Loop 2 - DB-1, DD 9800GX2 block, MCW30, MCR320, tLine res. |
I just got a Q6600 as well. How far do you think I can OC it with just the stock HSF? I got a CM 690 case so it has plenty of room for case fans. I don't really feel like shelling out another $50 for a aftermarket HSF and have to mount and clean up thermal paste etc again.
| That's why I grabbed that mobo! :) I figured 3.2 easily, my Zalman cooler is a beast, so hitting 3.6 with a little tweaking shouldn't be too hard.
| Quote:
| Do eet! One of the best things you can do for OC'ing, and really, after paying how much for your Q6600 does an extra $50 to get the most out of the chip really that bad? Actually, I think it doesn't make much sense to not get a aftermarket.
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Odds on a worthwhile step-up from 8800GT in the next 90 days? | rommelrommel | Video Cards | 2 | February 1, 2008 10:29 AM |
