Well I'm a lazy, lazy man, and I've already exceeded my budget for my pc by almost $100. Another $50 is hard to swallow, especailly since it will most likely be $60-$70 after tax. I've already posted at GA-P35-DS3L OC Time!, so if you can answer my questions and recommend a HSF for me I'm all ears. I'm just looking to hit 3.0Ghz, not crazy high. Quote:
Thanks for the info - but your HSF is about $75... the OP is looking in the range of $50.
__________________ Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182 HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B |
| Quote:
__________________ Antec NSK 6500 w/ TriCool intake, S-Flex F exhaust Corsair HX520 Gigabyte GA-965P-DS3 Rev1.0 @ 500FSB Intel C2D E6300 @ 3.5ghz 1.45V Arctic Cooling Freezer 7 Pro Mushkin (996576) 2X1GB HP2-6400 @ 1000mhz 5-5-5-15 1.9V eVGA 7600GT KO @ 630/880 Seagate 7200.10 320GB Samsung SH-162 Samsung 205BW Logitech Media Keyboard Logitech MX518 |
I don't think you need a better HSF. This is a screen shot of my X3210 quad that has been folding the last few days. Nice and stable at 3.2GHZ and temps while 90% CPU load folding are below 70. The 74 that shows as the max in HWMonitor was when I was running Prime95 for more than a day. I'm using an intel stock cooler!
__________________ The Vortex H20 Case....not sure what to call it DFI X38 LT Xeon X3210 @ 3.2GHZ 1.30V PNY 9800GX2 (750/2200) 4GB Corsair Dominator 2x2gb kit DDR2 1066 5-5-5-15 2.0V Ultra X3 1000W PSU HT Omega Striker 2x500GB Hitachi RAID 0, 250 Seagate Sharp 32" Aquos 1080p Benq W500 1080i Pojector. Watercooling: Loop 1 - D-Tek Fuzion Quad Nozzle Bowed, MCR320+Zalman ZM-F3 Fans, MCP655, MCRES Micro. Loop 2 - DB-1, DD 9800GX2 block, MCW30, MCR320, tLine res. |
Well I decided to go ahead and install some watercooling in this one....Anway, same settings and everything, temps are pretty awesome.....
| Quote:
I read that some people can do 2.9GHz on stock voltages with the q6600. When did you need to start stepping up voltages? Last edited by thenewguy001; March 7, 2008 at 05:07 PM. |
I am running it at 1.275V, just slightly above stock of 1.225. My chipset voltages are all set to Auto with no issues.
I was able to OC my Q6600 to 3.5Ghz on an Asus P5K with a zalman 9500 and only auto settings. You really dont need to know or do anything fancy with these chips to get them to go that fast, just up the FSB and keep an eye on the temps. With your board and a lesser HSF you shouldnt have to do much of anything to get it to your max temps, just fsb adjustment. Be sure to use a software temp monitor that will correctly display your temps though, coretemp does a good job, but there are alot out there that will read it 15 C cooler than it actually is.
__________________ vista 64 on these rigs Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz 8gb Muskin Redline. | 2gb Kingston Hyperx ________________________________|_________________ ______________ EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W. Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI 1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0 |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| Odds on a worthwhile step-up from 8800GT in the next 90 days? | rommelrommel | Video Cards | 2 | February 1, 2008 10:29 AM |
