Old March 3, 2008, 06:51 PM
Default Happy with my overclocking...
I'm pretty happy with my first really stable oc!!! I got my QX6850 up and running @ 3.6Ghz with core voltage set to 1.4v, fsb @ 400 mhz an multiplier @ 9... I know that chip can go further, but I haven't tryed to get it running at a higher rate since 3.6 ghz is perfectly ok with me !!! I hit about 28 degrees at idle and about 44 to 48 degrees at full load with prime 95 for 9 hours on air cooling.
Lapped Intel Qx6850 @ 3.7 Ghz @ 1.4 volts
Coolit freezone elite
Asus Rampage Formula
8 Gig Gskill pc2 8000 4x2gig
HIS HD4870X2
BenQ V2400W monitor
Pc power and cooling quad 750
Cooler Master Stacker 830
Old March 3, 2008, 07:01 PM
SugarJ's Avatar
Nice OC, Craig. But I predict you'll be happy for about 48 hours before you try to push that chip a little further.
How do you like your Merc Stealth keyboard? I was thinking about trying one.
Old March 3, 2008, 07:11 PM
magictorch's Avatar
very nice-is that with a TRU X.
Old March 3, 2008, 07:28 PM
Lol... yeah, I guess you might be right !!!!
I really like it... I think the gamepad is really sweet as well as the possibily to switch between 3 colors and intensity. I am having a little issue though ---> see this thread in the troubleshooting forum :
http://www.hardwarecanucks.com/forum...html#post43687
HIS HD4870X2
BenQ V2400W monitor
Old March 3, 2008, 07:32 PM
Smile
Thanks...Yes, it is a true X !!!
HIS HD4870X2
BenQ V2400W monitor
Old March 3, 2008, 07:41 PM
3.0charlie's Avatar
TRUx or, as per your signature a CNSP9700 LED?
Hydro-Quebec is salivating...
Old March 3, 2008, 07:43 PM
Whoaaa... Didn't know that image would show up that large...LOL !
HIS HD4870X2
BenQ V2400W monitor
Old March 3, 2008, 07:46 PM
LOL, sorry. I thought you meant the processor... I gotta CNPS9700 LED !
HIS HD4870X2
BenQ V2400W monitor
Old March 3, 2008, 09:53 PM
Babrbarossa's Avatar
ood OC but keep pushing it!
Nice board for gaming and is well built, but if you do much typing it's a pain in the ass because there are a few commonly used buttons that are piggy backed onto others and require a 'lock' key to use (like delete)
Old March 3, 2008, 11:14 PM
SugarJ's Avatar
Thanks Craig and Babrbarossa for your feedback on the Stealth. While I like my G-15, I'm always looking for a new toy to try. And of the last dozen games I've bought, 8 are FPS's, so might be a good match.
Tried pushing your OC yet Craig? C'mon, you can probably hit 9x425, can't you?
^stoking the fire^ JK, there's not much out there that will outperform your system.
Happy Easter BALISTX Off Topic 8 April 10, 2009 09:31 PM
Happy New Year Supergrover Off Topic 11 January 1, 2008 07:54 PM
Is that a PC in your pocket, or are you just happy to see me? sswilson Reviews & Articles from the Web 0 October 14, 2007 11:30 AM
Happy Thanksgiving BALISTX Off Topic 6 October 7, 2007 09:49 AM
New happy faces! Patriote Suggestions & Feedback 23 May 7, 2007 03:39 PM
