Old November 23, 2011, 10:34 PM
Default harddrive / overclocking help
Hello anyone who can help me :)
Recently i have removed all my harddrives sata and power cables to re cable manage them, i then pluged them back in all nice and now two of my drives wont show up in my computer or disk management.
i tryed changing around cables but the same drives still wont show up.
I recently got a noctua D-14 and i wondering how high you would recommend
overclocking my i5 750 (stock 2.67) for 24/7 use.
Cheers for any advice,
Old November 24, 2011, 06:28 AM
FreeKnight's Avatar
Have you checked in BIOS to see if the drives show up? If they're not appearing in your Hard Drives selections in BIOS you could either have bad drives or bad SATA cables. Double check your power cables too.
Old November 24, 2011, 02:36 PM
Or try swapping the cables around a bit, sometimes(though it shouldnt) having the wrong cable in the wrong ports can cause drives not to appear, and do make sure as other person said that cables are well seated, sometimes a little wiggle is enough to make them "talk" to the system again :P
As far as the cpu, 70c or below load temps, but each cpu overclocks differently, it all depend son many many things, a good speed though to keep it simple would be 3.4-3.6-3.8-4.0+Ghz, just mind your voltages and load temps and read read read, knowhow can not be given it has to be learned first :)
Old November 24, 2011, 06:30 PM
Default thanks
thanks for your advice guys im slowly working my way through all my drives and checking sata cables and connections i got an error when starting up saying missing NTLDR also.
harddrive , overclocking
Best way to test a new harddrive? Tempstar Storage 7 June 18, 2011 08:09 PM
[WTB] cheap ide harddrive flightsimnerd Buy/Sell & Trade 2 January 23, 2010 01:26 PM
Harddrive in Bios tom555 Troubleshooting 1 August 5, 2009 12:21 PM
[WTB] IDE Harddrive Enclosures! chibi_man Buy/Sell & Trade 2 December 2, 2008 09:10 AM
need laptop harddrive Rapid-X Buy/Sell & Trade 3 February 14, 2008 12:46 PM
