Old November 20, 2011, 10:13 AM
Perineum's Avatar
Originally Posted by Roby The Beast View Post
Energie saver may cause the system unstable no?
No, my overclocks are 24hr stable with Prime95 and all the energy savers and HT are still on.
Old November 20, 2011, 10:21 AM
Same, I'm stable 4.6 on my 2600K and was 4.8 on my 2500K with all energy saving features enabled. If you get up 49x 50x or higher multi, yes you might have to disable C3/C6, possibly even C1 and EIST.
2600K @4.6 for now, still tweaking.
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
EVGA GTX 580 SSC
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old November 20, 2011, 02:13 PM
Its already been said but do it anyway ...........leave the cpu to throttle back on the energy savings features
Mine runs according to my sig. and 64 bit prime 24 hours prime stable.
It will run and run
Cambridge,ON
MSI Z77 M Power/Bios17.7
i5 3570k@4.5ghz
Mushkin #997007
Noctua NH-D14
EVGA GTX460
Seasonic X-660
Antec P280
Intel Speed Demon Equipped
using Prime 95 27.9
i5 2500k Overclocking Kommie986 Overclocking, Tweaking and Benchmarking 23 April 9, 2012 09:29 AM
2500k overclocking Patriote Overclocking, Tweaking and Benchmarking 27 November 15, 2011 04:34 AM
Is this good overclocking for i5 2500K? ern88 Overclocking, Tweaking and Benchmarking 6 November 6, 2011 07:45 PM
Assistance with i5-2500K overclocking Modus Overclocking, Tweaking and Benchmarking 8 May 2, 2011 03:20 PM
2500K + P8P67 Pro Overclocking Realityshift Overclocking, Tweaking and Benchmarking 0 January 24, 2011 10:20 AM
