<~----> Q8400 Overclocking - Hardware Canucks
Old November 18, 2011, 04:27 PM
Trial Member
Question Q8400 Overclocking
So im updating this post since i changed some thing in my pc:
Mobo:Gigabyte ep43-ud3l
GPU: HD 6870
CPU: intel q8400 3.30 ghz stable i want to get it
CPU Cooler: Corsair h50
ram:8 gb ddr2 800mhz
hdd: Samsung spinpoint f3 1tb 7200rpm
PSU: Corsair TX 650 W
So first thing is how could i improve the performance. I did try and overclock the cpu and i does it great, but the thing is if i overclock it to lets say 3.30 it runs fine but on 3.40 it wont boot. What voltage for 3.40 or 3.6 if possible i heard that Q8400 can go up to 1.45v.
Thanks for answer.
Old November 18, 2011, 04:48 PM
supaflyx3's Avatar
You'll need to bump up the voltage too get it stable.
And use 2 fans in push-pull on your H50 drawing in cold air.
Old November 18, 2011, 07:35 PM
wrong thread
Cambridge,ON
MSI Z77 M Power/Bios17.8
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Antec P280
Intel Speed Demon Equipped
using Prime 95 27.9
Is a GTX 560 Ti 2GB a good match for a Q8400 quad core CPU? Linus LinusTechTips Q&A 5 October 20, 2011 12:46 PM
GTX 480 Overclocking ImmaPC Overclocking, Tweaking and Benchmarking 24 March 13, 2011 06:36 AM
i7-860 Overclocking anthonee1230 Overclocking, Tweaking and Benchmarking 6 November 28, 2009 05:09 AM
Needs some help overclocking lanken123 Overclocking, Tweaking and Benchmarking 0 April 21, 2009 11:51 AM
Overclocking and Cpu-Z CactusJoe Troubleshooting 15 December 9, 2008 01:59 PM
