Old March 2, 2008, 05:24 PM
BALISTX's Avatar
Default The Quick and Dirty OC.
As you all know the E8400s are on back order till April 20th So in the next few weeks I'll have the rest of my stuff for my rig minus the processor. So I was thinking about playing around with a cheap Celeron 420 that can be had for $37.60 from DC. At this price I don't care if I blow the CPU up.
As the title of the thread stats I'm gonna try and quick and dirty OC. First here is the list of parts then I will tell you my plans.
Motherboard: Gigabyte GA-P35-DS3L (Rev 2.0)
Memory: 2x1GB G-Skill F2 PC2-8500 DDR2-1066 5-5-5-15
Video Card: XFX 8800GT
Hard Drive: Seagate Barracuda 250GB 7,200rpm SATAII
PSU: Undecided (Between OCZ, Corsair and Mushkin, at least 550W)
Case: Coolermaster CM690
CPU HSF: Thermalright Ultima-90 w/Scythe 92mm
Case Cooling: 6x120mm fans
CPU Specs:
My plan is to set the FSB to 400MHz which I know is possible with the Gigabyte P35-DS3L board. Then I will set the vcore to 1.30v. My memory I'll probably set to 2.5 multiplier which will give me 1000MHz memory speed and see what happens.
This will OC the processor from 1.6GHz to 3.2GHz a 100% OC.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old March 2, 2008, 11:24 PM
Since you don't care about the CPU...you could go all out and go for 100%+
Set the VCore to as high as you can cool, and overclock away. Awaiting results...
As for your PSU, I'd say go with Corsair. I have an HX520, and it's top quality and maybe the quietest component in my system. I think the Antec Earthwatts are also worth a look.
Actually, NCIX has a surprise special for an Antec Trio 650W: http://www.ncix.com/products/index.p...6&promoid=1055
I almost got one of these instead of my HX520. I hear the newer ones have sleeved cables, and the pics are of the old ones.
Antec NSK 6500 w/ TriCool intake, S-Flex F exhaust
Corsair HX520
Gigabyte GA-965P-DS3 Rev1.0 @ 500FSB
Intel C2D E6300 @ 3.5ghz 1.45V
Arctic Cooling Freezer 7 Pro
Mushkin (996576) 2X1GB HP2-6400 @ 1000mhz 5-5-5-15 1.9V
eVGA 7600GT KO @ 630/880
Seagate 7200.10 320GB
Samsung SH-162
Samsung 205BW
Logitech Media Keyboard
Logitech MX518
Old March 2, 2008, 11:29 PM
I have a Corsair HX620W.. i just wanted it cause it was modular and apparantly good quality.. i'd recommend it to anyone..
Old March 2, 2008, 11:47 PM
BALISTX's Avatar
I had a corsair VX 550W before and it was awesome. I was thinking maybe the 520 cause it's modular
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Old March 3, 2008, 12:35 AM
Prof. Dr. Silver's Avatar
Good Luck Buddy! You can do it! And that FSB will go to 515MHz....Just make sure you cool your NB!
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old March 3, 2008, 12:55 AM
BALISTX's Avatar
Already got 40mm scythe fan for my NB.
Honestly I'd be happy with a 2.6Ghz OC or even a 3.0GHz OC at the most. Once I get my E8400 I'll use the Celeron in another rig (yet to be built) for either a HTPC or a dedicated folding/benching rig.
[Heatware]
[eBay]
[Rosetta]
BALISTX.com
Quick links - add My posts :) trodas Suggestions & Feedback 8 February 26, 2009 04:25 PM
Quick Question. Khronos Display Units 2 January 7, 2008 01:16 PM
Dirty Pool: Intel vs NVidia- AMD, here I come Babrbarossa CPU's and Motherboards 6 November 18, 2007 04:02 PM
Quick Simple question mattydies Overclocking, Tweaking and Benchmarking 3 October 19, 2007 06:44 PM
