| Quote:
what program are you using for the overclocking? |
| Quote:
![]() Here's what the average FPS's are; ![]() Also went with everything to max to see what score I'd get, still trying to break 10,000 :( ![]() ![]() Not bad eh? lol Here's the FPS's, not bad either I must say! :D ![]() Obviously my 5000+ BE is holding me back, but meh, still not bad.
__________________ Intel Core 2 Quad Q6600 "G0" 2.4GHz Overclocked @ 3.61GHz Zalman CNPS9700 LED Cooler Master Real Power Pro 750watt PSU Asus Maximus Formula BIOS v1004 8GB OCZ PC2-6400 800MHz Vista Performance Platinum Edition @ 5-5-5-15 2T Dual Radeon 3870x2's (Stock for now) WD Raptor 74GB 10,000rpm SATA | WD 500GB 7200rpm SATA | WD 500GB 7200rpm SATA LG DVD-RW Dual Layer SATA Antech 900 Advance Gaming Case 42" LG LCD 1920x1080p | BenQ W5000 1080p LCD Projector 155" Windows Vista Ultimate x64 |
Post a GPU-Z screenie too. But 3oh6 is right...that core clock you have on stock voltage is insane. It seems like you have one of the few that can clock that far which means that you are pretty lucky on that accord. BTW, don't forget to tune into the season finale of Terminator tomorrow!!! |
Am I the only one thats going to tell him his score is just a bit.. ( I mean a lot ) low? For comparison, The screenshot has a Single 3870 at 972/1332 but has been voltmodded, and I set the Voltage to about 1.45 for that to be stable. But I also scored a mere 200 points less than you with a single cored card. Ouch. ![]() - I know the cpu part looks messed.. thanks to ms paint but here's the image it was cropped out of. ![]() So why are the scores so low? I'm just curious since it seems off what I'd expect.
__________________ CPU: E4500@3.3ghz ( 300X11@1.430v) MB: DFI LanParty ICFX3200 T2R/G RAM: OCZ Platinum XTC rev2 ( 4-4-4-15 2t ) GPU: BFG 9800GTX COOLING: Swiftech 120 Compact - Swiftech - MCW30 SOUND: HT omega Striker 7.1 CASE: NZXT Lexa Blackline PSU : OCZ Gamestream 700w |
| ahhh...now try clocking both cores. 972 with one core is still pretty damn amazing but even more un-likely with both cores. Rivatuner is only able to overclock 1 core on my HIS 3870X2. perhaps with other cards it can clock both cores but i wouldn't think so. what you want to do is use Rivatuner for setting fan speeds but use AMD GPU Tool for clocking the cards. it will let you clock both cores and actually hold the clocks. AMD GPU Tool: http://www.3oh6.com/forum_posted/080...kTool_v0.7.zip that archive should already have the updated toolib.dll. just un-zip and run. be sure to set the clocks for both cores using the drop down menu. it will say that the overclocks weren't applied after you apply but they have been. just cycle back and forth between the cores to see the updated clocks. two words...AMD dual-core, that and he is likely only clocking a single core which puts them out of sync and doesn't help from the limited testing i have done with different core clocks. |
| Quote:
http://www.xtremesystems.org/forums/...d.php?t=175559 My results were fairly good (BOTH CORES): 959MHz/1000MHz/15678 3DMarks and YES, the AMD is a HUGE bottleneck for me right now, picking up a QX9650 for $350 (I know the owner of a store in T.O. hehe) So I'll be getting waaaaay better scores soon enough. :) Not able to get the CPU :( he sold it on me fracking prick! lol Grabbing the E8400 instead. :)
__________________ Intel Core 2 Quad Q6600 "G0" 2.4GHz Overclocked @ 3.61GHz Zalman CNPS9700 LED Cooler Master Real Power Pro 750watt PSU Asus Maximus Formula BIOS v1004 8GB OCZ PC2-6400 800MHz Vista Performance Platinum Edition @ 5-5-5-15 2T Dual Radeon 3870x2's (Stock for now) WD Raptor 74GB 10,000rpm SATA | WD 500GB 7200rpm SATA | WD 500GB 7200rpm SATA LG DVD-RW Dual Layer SATA Antech 900 Advance Gaming Case 42" LG LCD 1920x1080p | BenQ W5000 1080p LCD Projector 155" Windows Vista Ultimate x64 Last edited by saihossoku; March 3, 2008 at 10:16 PM. |
| He seems to be running 3DMark w/ higher res and settings. That'll pull down any card in a hurry. How about a quick run at standard settings for comparison?
__________________ QX9650 @ 4.038GHz (425x9.5) | Asus Formula Maximus | GTX280 (777/1620/1404) | Mushkin XP2-8000 Redline 2x2GB Q6600 @ 3.6GHz (400x9) | MSI P35 Platinum | 8800GTS 640MB (700/900) | Mushkin EM2-6400 2x2GB |
| No, no. lol Of course I used stock settings in 3DMark06, 12K+ is good for a 5000+ BE for my CPU. I did a run at full in 3DMark06 and got over 8000.
By the way, grabbed AMD GPU Clock, it won't let me change anything. I always get: ![]() What am I doing wrong? Thanks.
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| 3870X2 vs 9800GX2 | vdf22 | Rumor Mill | 19 | January 30, 2008 03:07 PM |
| Overclocking help | tzetsin | Overclocking, Tweaking and Benchmarking | 41 | January 28, 2008 12:05 AM |
| 3870x2 NDA pushed back -delay | Ugly n Grey | Rumor Mill | 19 | January 26, 2008 06:12 PM |
| Ati Radeon 3870X2 Benchmarks @ Tweaktown | didiet | Press Releases & Tech News | 20 | January 24, 2008 06:57 PM |
| Overclocking P4 1.8 | Kassela | Overclocking, Tweaking and Benchmarking | 1 | December 27, 2007 12:28 PM |
