Old March 1, 2008, 11:39 PM
Prof. Dr. Silver's Avatar
Hardware Canucks Reviewer
Originally Posted by Tumdace View Post
sorry to freak you out...
typo LOL
meant to say 1.165.. not 1.65
HAHAHAHAHAHAHAHAHAHAHA THIS WAS THE BEST JOKE EVER!!!! ROFL!!!!
Boy, was I ever scared for you!!! I figured by the time he reads this he CPU will be fried!
You can see your FSB in the BIOS...it is set at 333MHz now...you can manually set it to 400MHz
Old March 1, 2008, 11:41 PM
Originally Posted by Prof. Dr. Silver View Post
Okay new post without so much exclamation marks! Hope you read my post on time.
Lets do this step by step:
1. Start rig up
2. Open a can/bottle of....OC juice!
3. Go into BIOS
4. Press Ctrl + F1 This will unlock secret settings! LOL
5. Go to the overclocking section....ehm...lost the name now....at the bottom of your list....
6. Set Graphics Booster to Turbo
7. Set Multi to 9
8. Set FSB to 400
9. Set OC settings to 'Extreme'
10. Set RAM setting to manual
11. Set Ram divider to 1:1 (400MHz)
12. Set timings to 5-5-5-15
14. Set RAM voltage at what your RAM is rated for
15. Set CPU voltage at 1.25V
Then press F10 to save and restart. Let us know if that works! Then we talk some more!
also, no ram divider setting.. at least that i can see..
Old March 1, 2008, 11:42 PM
what is it labelled as? theres nothing in the MIT section (which is where all the timings get changed) that is labelled as FSB..
and as for performance enhance.. i left mine at standard.. it says it can provide stability when overclocking
Old March 1, 2008, 11:50 PM
Dude...I'm at work now....so I can't tell you off the top off my head....give me 45 min. and I should home! Then I'll guide you through the entire process! In the meantime check out this thread: GA-P35-DS3L OC Time!!!
Enjoy!
Old March 1, 2008, 11:51 PM
1. Start rig up
3. Go into BIOS
7. Set Multi to 9
8. Set FSB to 400
just tried this exactly (well not the ram divider, cause i have no clue where that is.. or the FSB... ) but i set cpu to 400, 9 multi, gives me 3.6, graphics to turbo, cpu voltage at 1.25v.. i dont know where to find my ram voltage..
my bios reset itself again... it cant even handle 3.6ghz? this is why i dont oc... this is pissing me off
Old March 1, 2008, 11:56 PM
BALISTX's Avatar
Level up: 54% Level up: 54% Level up: 54%
Level: 21 - 564 points to level up
When you press Ctrl+F1 go into the MIT settings. your memory divider is call the a Memory Multiplier on the Gigabyte boards. If you want a 1:1 ratio you want to set the memory multiplier to 2.
"Though I walk through the shadow of the Valley of Death I shall fear no evil as my C8 Carbine is locked and loaded."
Next Build: E5200 @ 3.6GHz (333x11) | Xigmatek HDT-RS1283 HSF | Biostar TP43D2-A7 | Mushkin Redlines DDR2-1000 @ DDR2-999 5-5-5-12
EVGA 9600 GT 512MB - 650MHz - 1800MHz - 1626MHz | Seagate 'Cuda 250GB 7200rpm SATA2 | Corsair VX550 | CM690 - Custom Atomic Orange Pearl
[Heatware]
BALISTX.com
k thanks..
but as for this overclocking.. either im doing something wrong or my cpu sucks... cant even handle 3.6ghz..
Old March 1, 2008, 11:59 PM
"Running those PC2-6400 makes it more trickier if were running PC2-8000 or even PC-8500 then you could do the folllowing:
FSB: 500
CPU Multi: 8x
Mem Multi: 2 (1000MHz)
I think the closest you might get would be CPU 440x9 (3960Mhz) / Mem 440x2 (880MHz)"
saw this in another thread... my ram is PC-8500.. does that mean i can do it? well that is if i can get cpu to overclock past 3.6ghz (3.6 would be nice for me.. but im aiming for 3.8)
  #19 (permalink)
Old March 2, 2008, 12:04 AM
BALISTX's Avatar
Try this. Leave your FSB at 400 and your CPU multi at 9. Then set your memory multi to 2 and leave the rest of your memory settings on auto. Also try upping your cpu voltage to 1.3 as there is a vdroop issue with these boards. Set your memory voltage to 2.1
[Heatware]
BALISTX.com
  #20 (permalink)
Old March 2, 2008, 12:06 AM
BALISTX's Avatar
FSB: 500
CPU Multi: 8x
You might be able to 500 FSB is harder to acheive on these boards cause the NB runs hot. Insure you ample cooling on your NB.
You could try 440x9 and then the memory multiplier set to 2
[Heatware]
BALISTX.com
E8400 Anywhere? BladeRunnerFan Hot Deals 12 March 25, 2008 12:50 PM
WTB: E8400 3.0 Ghz darksniperx Buy/Sell & Trade 0 March 6, 2008 06:18 AM
E8400 for $209.99 Shadowmeph Hot Deals 5 January 30, 2008 07:44 AM
Problems Overclocking with Gigabyte GA-P35-DS3L DukeNukem Overclocking, Tweaking and Benchmarking 8 December 13, 2007 05:35 PM
Problems Overclocking. Dethredic Video Cards 6 November 3, 2007 08:06 AM
