Old November 12, 2011, 10:48 PM
rjbarker's Avatar
1. Artifacts..yes back off as it wont be stable.
Bump up voltage / core / memory and test (gaming), your limit other than instability (artifacts / CTD), will be Temps.
I also use MSI AB, I always set my Fan speed to 77% when gaming, Max Temps I'm comfortable seeing is 75-80C....anymore than 80C I set my fan speed up further.
I do not use "auto" Fan speed at all. With AB you can also set up Fan Profiles, whereby fan speed will ramp up according to the Temps, you simply set-up the curve yourself.
I'm not a fan of testing with Furmark as it puts such a huge load on your GPU compared to the load the GPU will experience with heavy demand games (less)...CTD and high Temps in Furmark may in fact be perfectly fine gaming and really, I'm not interested in playing Furmark ;)
I also have OSD ( On Screen Display - accessed through MSI AB) running in the background so that I can monitor GPU:
1. Core Speed
2. Temps
3. Framerates
while in-game !!
Firestrike Extreme: 21.452
MARK 11: 32.530
Old November 16, 2011, 09:14 PM
Thanks, thats exactly what I needed to know! Appreciate the help.
Old November 18, 2011, 08:09 AM
subscribed here! :)
a build base on 980x botat29 New Builds 3 January 10, 2011 05:20 PM
Imperfect Megahalems Base CroSsFiRe2009 Air Cooling 46 August 28, 2010 07:32 PM
Water line broke and then anouther line broke muse108dc Off Topic 3 March 28, 2009 07:34 AM
Xigmatek HDT-SD964 Exposed Heatpipe Base Heatsink Review Hardware Canucks Air Cooling 0 April 30, 2008 09:24 AM
Ultra 120 Extreme Base enaberif Overclocking, Tweaking and Benchmarking 13 January 22, 2008 09:37 PM
