Old November 6, 2011, 05:08 PM
ern88's Avatar
Default Is this good overclocking for i5 2500K?
Hey guys,
Well, I just took my i5 2500K to 4.5 GHZ. I am using the Zalman CPNS10X quite cooler. All I did was increase the multipliers to 45. Didn't touch anything else. I ran prime 95 for 10 minutes. And never got any errors and The CPU reached 50 C.
Old November 6, 2011, 05:18 PM
Some say you need to run it 12 hours, some say 24 hours. 10 minutes is definitely not enough. I have had BSOD's 5+ hours into prime95. Some boards and chips will do a steady clock to 4.5 with just the multiplier though. :)
Btw what are you using to check your temps?
Old November 6, 2011, 05:25 PM
ern88's Avatar
I am using RealTemp beta 3.69.1.
Old November 6, 2011, 05:34 PM
Yup, I've had it crash after 5-6 hours also. You don't see peak temps until 30-40 minutes into it.
2600K @4.6
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
Gigabyte GTX780
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old November 6, 2011, 05:38 PM
Shadowmeph's Avatar
I tested mine for 1/2 hr everything seemed good then and it was I played a game or two started folding then I decided to fire up irc to go to the HWC and I crashed lol that was just enough to crash me
Old November 6, 2011, 08:37 PM
Perineum's Avatar
For the overclocks I do for my clients it's a minimum 24hr prime95
I've had many fail between 5 to 8 hours.
Old November 6, 2011, 08:45 PM
Honestly it probably is stable just because 4.5 ghz is pretty easy on an i5 2500k, not many people are unlucky enough to have a chip worse than that but you really should run prime 95 at the very least all night while you sleep.
Anyways time for some real world testing on BF3
i5 2500k Overclocking Kommie986 Overclocking, Tweaking and Benchmarking 23 April 9, 2012 09:29 AM
2500k overclocking Patriote Overclocking, Tweaking and Benchmarking 27 November 15, 2011 05:34 AM
2500k RAM AKY RAM 10 July 10, 2011 02:09 PM
Assistance with i5-2500K overclocking Modus Overclocking, Tweaking and Benchmarking 8 May 2, 2011 03:20 PM
2500K + P8P67 Pro Overclocking Realityshift Overclocking, Tweaking and Benchmarking 0 January 24, 2011 11:20 AM
