Old November 6, 2011, 10:51 AM
Jonesy's Avatar
Default 2600k @ 5.0
Well, decided to see what my CPU could hit today.
Sitting stable after 10 minutes of Prime95 @ 5.0
x50 Multiplier
100Mhz Bus Speed
Vcore: 1.44
Ram @ 1333 (Can't get stable at 1600 without pushing the Vcore up beyond my cooling capabilities)
100% load I am peaking at 83c, 5.0 is just too much for the NH-D14 would need to look into better cooling solutions such as a custom loop if I want to push higher / stay at 5.0, the temp is just far to high.
CPU-Z Validator 3.1
Posted edited to highest stable Clock speed
I think I am going to look into dropping a CPU only custom loop into the rig, to see if I can get some better numbers. I just don't really have $500 to blow (or w/e it costs) Nor am I certain that the RV03-B supports an internal loop, and external systems aren't really an option with my 2 and 3 year old nephews at the house every other day.
Origin ID = xXFlatlinedXx
Old November 6, 2011, 10:59 AM
Dunno how much voltage you've fed it, above the 1.424 I see in the screenie, but that's about right for 4.8. You probably need a lot closer to 1.5v to hit 4.9.
With BCLK at 103, you're probably overclocking your RAM, which in the 67/68 chipsets, can be a big barrier. Set your RAM speed, timings, and voltage MANUALLY, don't allow any memory turbo or other enhancements. If you really want to see what your cpu will do, downclock your RAM to 1333 (and set everything manually) and work on your cpu multi. You've got the best possible overclocking motherboard. Would have to see your bios settings to make any other suggestions. But isolate the cpu is what I suggest for this chipset, then speed your RAM back up after you stabilize the cpu.
2600K @4.6 for now, still tweaking.
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
EVGA GTX 580 SSC
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old November 6, 2011, 11:12 AM
Jonesy's Avatar
Ya, I have just hit 4.9 @ 1.4v
x49 multiplier
100 BCLK
71c @ load
Ram was sitting somewhere around 1649 @103, sitting down at 1600 now. I will pop it down to 1333 and see how far I can push the CPU, before hitting the 1.5v
However from all I have been reading it seems that my Vcore is low for a 4.9Ghz clock speed, so maybe I manage to get a strong chip.
CPU-Z Validator 3.1
I kind of got excited at the 4.84, and didn't spend enough time tweaking to get optimal performance with what I have.
If I can get it into the 5.0ghz range I will 8hr Prime it and see if it is actually stable. CineBench 11.5 can only test stability for a short period of time.
Old November 6, 2011, 04:29 PM
Jonesy's Avatar
Well, 3hrs into the prime test @ 5.0Ghz, my system shut down due to temp's...My CPU climbed up into 86c, CPUID Hardware monitor crashed, then comp shut down. I need better cooling for both my basement (it is toasty down here) and the CPU before I go back to 5.0Ghz to fully check the stability of the O/C I had reached.
I guess it is time to pull out the Credit card and look into water cooling.
Old November 6, 2011, 04:33 PM
Your computer didn't crash due to temp, it crashed due to insufficient vcore. Thermal throttling isn't until 95C and even that won't crash the system, just slow it down.
P8Z68-V Pro Gen3
EVGA GTX 580 SSC
Corsair Gold 850W
Corsair H80
Old November 6, 2011, 05:01 PM
Jonesy's Avatar
Ah. I wasn't sure. I figured heat, because as it rolled up to 86c, Hardware Monitor froze up, and about 30-40secs later my system re-booted. I know the Vcore seemed rather low for 5.0Ghz, I just don't feel safe bringing it any higher then 1.44 with my temperatures. Going to be buying a W/C loop in about a week, so I can get stable.
Old November 6, 2011, 06:00 PM
Your_friendly_gamer's Avatar
x50 Multiplier
100Mhz Bus Speed
Vcore: 1.44
CPU-Z Validator 3.1
Did you actually change the vcore in bios to 1.44? or did you leave it at auto? because at 5.0 and only 1.44 v it won't boot, yea I have heard people say they can, but it's virtually impossible.
Also as others suggested, set your ram to manually and don't change the base clock. I had 2x4gig gskill 1600 mhz kits and I just had the timings set to to 9 9 9 24 and at 1600 and it worked fine at 5.0 ghz.
Also there is a guy here and I think he is a professional clocker his name is zsamz, I was having issues going past 4.8 ghz, he told me to change the memory voltage to 1.55 and it worked like a charm.
When I did the cpu-z I dont have that no more, unless i have it somewhere in my hard drive but no system yet:( it would show similar I believe 1.42 or 1.44 cant remember for sure.
However, the best clock I found was 4.5 ghz at bios vcore at 1.36 but it would never hit more than 1.32. I was also using a prolimatch megha with 2 scythe slip stream 1900 rpm fans and I never hit 58 degrees on Linx, on prime the mas I would hit was maybe 55 degrees.
Old November 6, 2011, 06:01 PM
That's a good plan if you insist on going further. Keep in mind though, you'll never feel the difference between 4.8 and 5.0 for gaming or whatever...and you're not going to own any world record benchmarks without much more advanced cooling....so those last 200 (or maybe you're REALLY lucky and you get 5.1 or 5.2 so 300-400) Mhz are going to be expensive
I don't think you've said, but *if* gaming is your main usage, a vid card upgrade is a much better use of the money
P8Z68-V Pro Gen3
EVGA GTX 580 SSC
Corsair Gold 850W
Corsair H80
Old November 6, 2011, 06:36 PM
Jonesy's Avatar
While yes, gaming is the main usage..I just want to see where the chip will go, I know the difference wont be noticeable. Also, in order to get higher FPS then 2x 460's, I need 2x 560's and up (need sli of anything in the 5xx series minus the 590, so the price is much higher then the W/C will be)
Your_Friendly_Gamer - I manually set the Vcore to 1.44, and I did boot to OS, like I said I ran Prime95 for 3hrs @1.44Vcore
Currently running 4.6Ghz @ 1.32Vcore until I can get some better cooling. Still need to Prime it for a period longer then 2hrs
2600k / Z68 build Jonesy New Builds 13 September 23, 2011 02:01 PM
Help for a OC I7 2600k Alpine Overclocking, Tweaking and Benchmarking 39 April 4, 2011 12:54 PM
Questions... i7-2600k vs SR-2 Grampa HardwareCanucks F@H Team 29 March 11, 2011 04:21 AM
2600k benchmark botat29 CPU's and Motherboards 12 January 17, 2011 02:03 PM
