thats odd. the only thing i can suggest is to try re-mounting your hr-03. maybe the cooler isnt making 100% perfect contact with something? i got mine up a little passed ultra speeds on stock cooling using riva tuner pretty easily. i actually never found the 'top' where it started showing artifacts before my motherboard had to get rma'ed. my temps were a lot higher than yours too (~70 under load). hopefully its not a sign that something is wrong with your video card...
__________________ rampage formula , e6850 + ocz vendetta 2, mushkin xp 2x2g pc2-8500, xfx 8800gtx, zeus 750w psu, cm ammo 533, hdds, dvd writer, fans, cables etc... |
Hello tom, Yes despite the great temps I will give that a go. The core is so huge and I just put about two rice size pieces of MX-2 in the middle. Also any idea where the shaders or stream processors are located-on the core? I wondered if the HSI sink was making good enough contact, plus the MOFSET sinks which I attached after cleaning only have very fine 3M tape. Memory has lots of copper sinks ![]() Anyway despite ATI tool displaying artifacts/yellow dots at 1048-58 shader clocks- it is still able to run games or 3Dmark at higher shader clocks than this with no indication of a problem....Although increasing the core and mem gives the "sameish" result as increasing core, mem and shader. Finally there are some reports of some 8800GTX that have problems with shader speeds over 1058....something to do with the oc bios in the card. Hopefully its just a mount issue and nothing more sinister. I do have a very high pitched noise (have done for sometime) which does "now" seem to come from the card and gets a bit worse with stress...its barely audible though as its such a high frequency and not everyone can hear it.
__________________ E6750/ Xeon 3350 DFI X38 LT 2 x 4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black). Loop 1: MCR 220 int. ; Apogee GT block. Loop 2: MCR 320; Swiftech Res.; 2x EK FC blocks. Pumps: 2x MCP655. Last edited by magictorch; February 29, 2008 at 09:27 AM. |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| My 8800 Ultra/ E6600 Clocks | Hillsdale | Overclocking, Tweaking and Benchmarking | 3 | December 19, 2007 01:26 PM |
| Problems with overclock | FritzGuy | Overclocking, Tweaking and Benchmarking | 6 | December 10, 2007 07:14 PM |
| Bad overclock settings? | magictorch | Overclocking, Tweaking and Benchmarking | 0 | December 2, 2007 01:59 PM |
| 24/7 Overclock? | bushwickbill | Overclocking, Tweaking and Benchmarking | 5 | August 25, 2007 05:32 PM |
