Old November 3, 2011, 03:03 PM
Question Overclocking HELP!!
Hey! I want to overclock my cpu, but i don't have a clue about how to do it. I have searched aound but haven't find anything useful. Thats why im asking you! :)
I have an Asus P7P55D-E LX motherboard, an intel I7 870 2.9GHz, Coolermaster V10 CPU-Cooler, 400watt PSU and two RAM memories with 4gb each with 1333MHz.
So i wonder how much I'm able to overclock my processor to?, and what settings i should use in my bios?. My "Mission" is to oc my cpu to 4GHz if that's possible.
Thanks!
//Elias Alm
Oh and sorry for my bad english, im from sweden :P but i hope u will understand!
Old November 3, 2011, 03:09 PM
Most of the time you can google it an find it that way also go to a 3d party website to download some software ...hope this helps a little ....i found a website just by searching google :)
Core i7 Overclocking Guide For Beginners
Old November 3, 2011, 03:17 PM
Default Thanks!
thanks for helping, but i have only one prob, i don't know what settings i should have for my specific motherboard. i will search around a little more ! :)
Old November 3, 2011, 03:57 PM
69_Goat's Avatar
Miahallen at TechReaction wrote some of the best overclocking guides I have seen.
Read through them, follow the steps, and you should learn alot along the way.
Here is a link for the Lynnfield guide.
3 Step Overclocking Guide – Lynnfield | TechREACTION
Old November 3, 2011, 05:06 PM
FlyingFish's Avatar
There's no specific settings for any motherboard.
Just raise the bclk by 10mhz at a time, stopping to run prime 95 for at least an hour. Then when you find an overclock that fails prime95 raise the voltage a bit and run prime 95 for a while and keep going from there till you hit your desired 4.0, then run Prime for 24 hours. If it doesn't crash then you're good.
This is my signature. There are many like it, but this one is mine. My signature is my best friend. It is my life. I must master it as I must master my life. My signature, without me, is useless. Without my signature, I am useless.
Old November 3, 2011, 07:22 PM
dandelioneater's Avatar
check out this guide: P55 overclocking guide, and this quick vid: linus' P55 overclocking tutorial
For 4.0GHZ you will probably need about 1.375Vcore set in bios.
Tags
asus p7p55d-e lx , cpu , intel i7 , overclock , overclocking
gpu overclocking Jim Clifford Video Cards 5 May 30, 2011 05:34 PM
GTX 460 Overclocking jcmaz Overclocking, Tweaking and Benchmarking 2 December 3, 2010 07:33 AM
Overclocking Help Plz appplejack Overclocking, Tweaking and Benchmarking 3 January 4, 2009 11:50 PM
AMD Overclocking ?? cwestwell New Builds 16 October 20, 2008 01:39 PM
Overclocking P4 1.8 Kassela Overclocking, Tweaking and Benchmarking 1 December 27, 2007 12:28 PM
