Old November 2, 2011, 02:59 PM
Pabz0r545's Avatar
Default Your grandmother could do it!
Overclocking so easy even your grandma can do it! - YouTube
Old November 2, 2011, 03:37 PM
martin_metal_88's Avatar
then let the PC reboot and reboot because you haven't played with voltage or lot's of other variable :)
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old November 2, 2011, 03:49 PM
Silvgearx's Avatar
My Grandma is already 6 feet under.
Old November 2, 2011, 03:52 PM
Pabz0r545's Avatar
^^ Same but no need to be emo about it. :P RIP Grandmas..... they are the best people of life.
It really is that easy. Mine will go to 4.2ghz stable with just changing the multiplier. Some will go to 4.5.
