Old October 15, 2011, 01:29 PM
Kommie986's Avatar
Default i5 2500k Overclocking
I followed this guide: P67 Sandy Bridge Overclocking Guide For Beginners but when I stress test with Prime95, after a bit, it always says something along the lines of Prem95 having an error and needing to close. I followed his exact instructions for 4GHZ except I pumped voltage up to 1.15
Old October 15, 2011, 01:35 PM
supaflyx3's Avatar
Not every chip is the same.. also that guide is using a 2600k, up your vcore to 1.2
Old October 15, 2011, 01:59 PM
Kommie986's Avatar
Aight thanks!
Edit: Also, what's the highest safe voltage for these Sandy Bridge chips? I really want to hit 4.5 GHz.
Old October 15, 2011, 03:40 PM
SugarJ's Avatar
You have an Asus board right? Try the auto-oc. It took my 2600k to 4.5Ghz with no problems.
Old October 15, 2011, 04:11 PM
Kommie986's Avatar
Hm, I'll give that a shot. Thanks!
Old October 17, 2011, 01:45 AM
bradleyg5's Avatar
1.52 is the max voltage, you are in my opinion perfectly safe under 1.4 as long as you cool it properly, nothing wrong with running over 1.4 either :P
Old November 26, 2011, 07:33 PM
NO to auto oc, change voltage to 1.35v for 4.5ghz, ~1.25v for 4.2ghz
Old November 26, 2011, 09:50 PM
Dead Things's Avatar
Maybe. Maybe not. Not all chips are the same.
Auto OC will work for the OP's specific hardware, which makes it a decent starting point.
Join the PPD revolution!
Proud to be Folding @ Home
deadthings @ Team 37412
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Old November 26, 2011, 10:37 PM
I forget what it's called, but the auto o/c on the dumbed down first bios screen took me to 4.4 no issues.
2600K @4.6 for now, still tweaking.
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
EVGA GTX 580 SSC
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old November 27, 2011, 10:51 AM
I know not all chips are the same, but it is the recommended voltage to start off with on the 2500k, I've built a few computers for my friends with 2500k, and got it up to 4.5ghz with 1.35ghz. Of course I would run prime and check if its enough voltage, some chips can run 4.5 at only 1.25ghz, but for most chips 1.35 is the best voltage to start with. The turboevo utility also overclocks baseclock and overvolts, so I would recommend doing it manually, there are plenty of forums online with the speed people are running their 2500k at and the voltage, so you can get an idea the amount of voltage required.
H50/i5 2500k fan speed Livestrong Water Cooling 5 August 6, 2011 06:20 PM
2500k RAM AKY RAM 10 July 10, 2011 02:09 PM
Assistance with i5-2500K overclocking Modus Overclocking, Tweaking and Benchmarking 8 May 2, 2011 03:20 PM
i5 2500K @ 4.8 GHz oddities SneakySnake Overclocking, Tweaking and Benchmarking 4 March 9, 2011 03:08 PM
2500K + P8P67 Pro Overclocking Realityshift Overclocking, Tweaking and Benchmarking 0 January 24, 2011 10:20 AM
