Old December 20, 2011, 10:02 PM
Zer0's Avatar
Currently I'm Prime95 and LinX stable with 1.33V. I thought it was okay at 1.28V but got rounding errors on one of the cores during the Blend test. I'm slowing working my way down again to see how low I can go.
2500K @ 4.5Ghz (1.33V with Level 7 LLC)
Gigabyte Z68XP-UD5
Corsair Vengeance LP 1600Mhz 4GBx2 9-9-9-24 (1.35V)
Old December 21, 2011, 07:32 AM
Auto OC may in fact put the BLCK setting from 100 to 102
I wouldn't want that but your mileage may vary.
Read the Asus tech reprsentatives settings and recommendations for these boards.
Its online. At Hard OC
Heck I even have my cpu capability at 100% only and I get my sig. 4.7
Cambridge,ON
MSI Z77 M Power/Bios17.12
3770K@4.5ghz
Mushkin #997007
Noctua NH-D14
Gigabyte GTX 660
Seasonic X-660
Corsair 540 Cube
Noctua case fans
Intel Speed Demon x 2
Win 10 Pro x64
Old January 11, 2012, 05:01 PM
ultraman7k's Avatar
So i tried the Asus auto-OC thingy on the bios, and my computer now has to restart itself several times on a cold boot.
I'm thinking it's trying to figure out what voltage to supply to the CPU.
I'm getting really tired of it, so I was wondering what's the maximum voltage for the 2500k (just so I know so that I don't ramp it up to the max lol).
Thanks.
Old January 11, 2012, 05:13 PM
Zer0's Avatar
Thanks.
I read the max safe voltage (according to Intel's technical docs) is 1.51V as long as your temps are under control. What clock speed are you trying to achieve? I would start off at 4.5Ghz with 1.32V then lower the voltage until Prime Blend is unstable and bump it back up a bit.
Old January 11, 2012, 06:19 PM
ultraman7k's Avatar
Awesome thanks. I was having trouble finding the multiplier but I figured it out. Thanks!
edit:
Actually, is it normal for CPU-Z to show that my core speed and multiplier is changing from 1600mhz (multiplier @ 16) to 3800mhz (multiplier @ 38) when i open up a program or do something? Is it purposefully underclocking??
edit#2:
Anyways bumped up the multiplier to 42, so I should be running 4.2ghz at 1.25v...now to test.
Old January 11, 2012, 06:59 PM
gingerbee's Avatar
yes it's normal it's speed step "eist" Enhanced Intel SpeedStep® Technology - How To Document
Old January 11, 2012, 07:20 PM
Thanks.
restarting on a cold boot means the overclock has failed.
max voltage is 1.4-1.45
Old January 12, 2012, 11:33 AM
mine is 1.39V stable at 4.5ghz.. I am fooling around iwth 1.43V @ 4.8ghz. prime 95 was showing 62C max.. All on my 20$ CM212+ cooler.
I have a cheap asrock z68 extreme gen 3 MB to boot.
  #19 (permalink)
Old January 12, 2012, 04:42 PM
my 2500k is stable at 5.0Ghz with 1.552v but i have water cooling
  #20 (permalink)
Old January 17, 2012, 05:55 AM
*grins* btw if you want to play it safe 1.4v
watch your heat levels if your on air
H50/i5 2500k fan speed Livestrong Water Cooling 5 August 6, 2011 06:20 PM
2500k RAM AKY RAM 10 July 10, 2011 02:09 PM
Assistance with i5-2500K overclocking Modus Overclocking, Tweaking and Benchmarking 8 May 2, 2011 03:20 PM
i5 2500K @ 4.8 GHz oddities SneakySnake Overclocking, Tweaking and Benchmarking 4 March 9, 2011 04:08 PM
2500K + P8P67 Pro Overclocking Realityshift Overclocking, Tweaking and Benchmarking 0 January 24, 2011 11:20 AM
