Old October 12, 2011, 08:12 PM
Default Silverstone FT02 and Silver Arrow make good buddies!
I finaly got around properly putting some voltage into my 2500k chip, I got it rock stable at 4789Mhz@1.410v. Ill do a full system build thread tomorow or something once i get some decent pictures but here is what I got so far.
You guys think I can push it more?
The system (sorry for the low res shit phone pic)
system specs are:
Silverstone FT02
Asrock Extreme4 mobo
2500k @ 4.8Ghz
Corsair Dominator 1600 ram
Asus GTX570 DirectCU2
Thermalright Silver Arrow HSF
XFX 750W black edition
Old October 13, 2011, 09:48 PM
Silvgearx's Avatar
3 minute prime?
Old October 13, 2011, 09:59 PM
Hahaha was gonna say the same thing. Voltage is in the right range though...run that P95 blend for 12 hours and get back to us :P
Also, recommend running either RealTemp (which also has a timer, so start it at the same time as P95 for double verification on length of run) OR the latest CoreTemp...both will monitor your current temp + give you a max over time number (ie, if it hit 80C but hours ago, you will see 80C as your max). Report back with temps. **EDIT** I see the HW monitor with temps now. Guarantee, you'll see a lot more than what you're getting now if you let Prime 95 run.
I'm at 4.8 at 1.428v (could not stabilize at a reported 1.416, the same number showing on your CPUz), max temp 70C peak, 65-66 avg load (22C ambient) if you want a frame of reference.
2600K @4.6 for now, still tweaking.
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
EVGA GTX 580 SSC
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old October 13, 2011, 10:23 PM
I understand the need to run a 12h prime for rock solid stability but bottom line I only use my comp for fun, and well i want to keep the electric bill low so ill pass on that :P It hasnt crashed any program since the OC, very stable for what I do!
Corsair AX850 PSU + Silverstone FT02 case juice99 Troubleshooting 6 January 6, 2011 08:24 AM
Corsair 800D or Silverstone FT02 Fortress CoolHandL Cases 26 September 28, 2010 10:13 AM
Thermalright Redefines Enormous With HR-02 and Silver Arrow CPU Coolers FiXT Press Releases & Tech News 19 June 24, 2010 11:58 AM
Silverstone FT02 StockClocker Case Mods, Worklog & Gallery 15 April 6, 2010 03:21 PM
SilverStone Fortress FT02 Prepping for Release FiXT Press Releases & Tech News 12 December 10, 2009 05:11 PM
