Hi guys, My idle temps are 53/51 max My load temps are 73/71 max They seem to really depend on the ambient temp... Right now, with ~20 ambient temp, the idle temps are 47/46, and load temps are 68/65. Are they OK, and do they seem to be about what I should be getting? Also, is a few degrees different between the cores normal? Should I remount the HSF? Thanks. SPECS: Antec NSK6500 (120mm LOW TriCool Intake in 92mm intake, Scythe S-Flex F exhaust) Corsair HX520 Gigabyte 965 DS3 rev1.0 (40mm Scythe Mini Kaze on NB) E6300 (3.5ghz, 1.45V) w/ Scythe Ninja, SlipStream 1200rpm) Mushkin 2GB HP2-6400 (1000mhz 5-5-5-15) eVGA 7600GT KO Seagate 7200.10 320GB |
Seems high to me, but perhaps my system just tends to run cooler. totally different set up. My idles usually sit at about 30deg with my full load on Prime95 over night sitting in the low 40s. your numbers look more like GPU temp readings not a CPU. What program are you using to measure your temps?
__________________ CasheKicker RIG #1 - AMD64 3500+ // Asus A8N-E // Radeon x1950xt // 2g Ram (4x512) // Basic Budget Case // Enermax Liberty SLI 500W Modular PSU // WD Caviar 250g RIG #2 - Intel E8400 // TRU-X 120 w noctua NF-P12 // Gigabyte GA-X38-DQ6 // nVidea 8800GTS 512 OC // 4g Ram Crucial Ballistic PC8500 1066Mhz (4x1g) // Antec 900 Gamers Case // OCZ 850w Gamer XTream PSU // WD Raptor 150g // Samsung 226BW & 17"KDS CRT/ Logitec G-15 |
| Quote:
![]() Quote:
Actually pushing an E6300 to 3.5 is very good, with only 1.45V. I don't know if your temps are right on track though - since I don't trust TAT. Use Coretemp instead. If you really want to see some CPU being pushed to its limits temp-wise, try OCCT... Download - OCCT Website english
__________________ Main: GA-X58-Extreme - i7 920 - TX750W - Raptor - 3Gb DDR3-1333 Triple-Channel - GTX260 SLI'ed - TRUE - P182 HTPC: M3A78-EM - 5000+ X2 - HX520W - 'cuda 1Tb - XP2-5300 2x512Mb - 9800GT - SI-128 - Prelude - Moneual 932B |
Does are some pretty good clocks you have going on. For what I read about that CPU, everything is safe as long as you don't exceed 70C
__________________ AMD Athlon 64 X2 4600 2.4Ghz, OC to 2.71Ghz Motherboard: Asus Crosshair Cooling: 4-120mm, 2-80mm fans, CPU-Blue Orb 2 Memory: OCZ 4 GB DDR2 800Mhz Video Card: Ati 1900XTX, OC to 688/792 Harddisk: Western digital 150Gb 10,000rpm CD/DVD Drive: Who knows (it works) CRT/LCD Model: 19" Samsung SyncMaster 940bf Case: Thermaltake Armor Sound Card: Original Audigy PSU: Thermaltake TWV 500W Software: Windows XP |
- great oc - once you start going over 70, I believe the safety mechanisms start to kick in since you are pushing close to the 85 Celsius max. I believe you can check for throttling with a program like Everest, if you have it - TAT is for mobile processors, it is unreliable for our CPUs. Coretemp was mentioned as a good alternative, and auto-logs to a txt file. - Speedfan is also a good program, but may read a different temperature than Coretemp (~15 less) which you adjust for in the program's config section. It can also read your HDD SMART info, so you can check on them once in a while to get a heads-up as to whether or not there may be problems with them.
__________________ Gigabyte P35-DS3R | E2180 @ 3.4ghz | Thermalright Ultra 120 Extreme w. Scythe | Mushkin Redline PC2-8000 5-5-5-15-2T @ 510mhz | BFG 8800GTX OC | 1.32TB WD HDDs | Corsair HX 620 W | Antec 900. Intel E1xxx & E2xxx OC Thread |
Would there be any reason other than something on my board being weird as to why I cant use: Coretemp, SisSoftware Sandra's Monitoring, Speedfan, They all make my computer buzz for 1second then do a hard lock. The only thing I can use to monitor my temps is ITE Smart Guardian, and Everest.
__________________ CPU: E4500@3.3ghz ( 300X11@1.430v) MB: DFI LanParty ICFX3200 T2R/G RAM: OCZ Platinum XTC rev2 ( 4-4-4-15 2t ) GPU: BFG 9800GTX COOLING: Swiftech 120 Compact - Swiftech - MCW30 SOUND: HT omega Striker 7.1 CASE: NZXT Lexa Blackline PSU : OCZ Gamestream 700w |
| Quote:
@Keir : You have a DFI board? If so, just use SmartGuardian. |
Nice OC but personally Id be careful with sustained 70oc temps. The cpu may not fully "protect" itself by throttling down. BTW have you considered the thermalright ultra extreme. I just switched my sythe ninja out for one...oh man does it make a huge difference in load temps at high oc's (14oc in my case!). They were selling them at Dc for $~49-and you can price match at NCIX .
__________________ E6750/ Xeon 3350 DFI X38 LT 2 x 4870 74gb Raptor for OS, games Thermalrock Dragon Case (sprayed black). Loop 1: MCR 220 int. ; Apogee GT block. Loop 2: MCR 320; Swiftech Res.; 2x EK FC blocks. Pumps: 2x MCP655. |
| Thread Tools | |
| Display Modes | |
Similar Threads | ||||
| Thread | Thread Starter | Forum | Replies | Last Post |
| temps | Kassela | Troubleshooting | 7 | March 13, 2008 03:46 PM |
| Northbridge Temps | bobcat | Water Cooling | 9 | February 6, 2008 06:26 AM |
| GPU temps | Infiniti | Water Cooling | 1 | December 23, 2007 10:10 AM |
| Good Temps for WCed PC? | Infiniti | Water Cooling | 10 | September 22, 2007 08:21 PM |
| ram temps? | bushwickbill | RAM | 5 | August 31, 2007 06:35 PM |
