Old February 23, 2008, 11:48 AM
Level up: 45% Level up: 45% Level up: 45%
Level: 10 - 154 points to level up
Default A question on Overclocking a 6800GT.
Hi there.
I would like to better understand my situation. Understandably heat is the premier concern when overclocking. I have an eVGA 6800GT that is a real workhorse. I can overclock it to Ultra Specs (400MHz core 1100MHz memory) and even top it out at 418MHz core 1102MHz memory. I can go higher with the aftermarket cooler fan I have but here is my question. When I go higher I see occasional artifacts, very minor such as a very small area (pen cover size) on the screen.
Why does the card declock itself after a short time down to stock core (memory stays overclocked)? The temperature remains stable at about 59C (ambient is in the 30s) and jumps up to low 70s when under load (such as high setting gaming).
I am using nVidia's built-in utility but I have also tried RivaTuner. My current driver is NGO NVIDIA Optimized Driver 1.16925.
Overclocking help tzetsin Overclocking, Tweaking and Benchmarking 41 January 28, 2008 12:05 AM
Overclocking question (Voltage) Wasza Overclocking, Tweaking and Benchmarking 2 January 22, 2008 11:28 AM
Need help overclocking further Kessler Overclocking, Tweaking and Benchmarking 15 December 5, 2007 06:09 PM
Need some help on Overclocking ShinseiKen CPU's and Motherboards 10 July 11, 2007 08:41 PM
How to install a 7900GTX heatsink on a 6800GT Misoprostol Video Cards 14 March 22, 2007 06:52 PM
