Old February 21, 2008, 08:23 PM
kcksteve's Avatar
Default Athlon +6000 OC
Hey guys jus a couple questions with regards to my oc. I have a biostar t-force 560 A2+ and im oc'ing my +6000 now with the ht link at 5x i can only get my fsb to 207 (from 200) but when i drop the ht link to 4x and up the chipset to 2.75v i can get it to 223 but it is unstable i tried loosening ram timmings ,upping the cpu voltage and upping the ram voltage but alas she stays unstable. right now i have it stable at 213 (cpu @ 3196.9), i have a noctua on the chipset and stock cooling(idle at 32* load 41*) anyone know how to check chipset temps? Id love to be able to get this higher any suggestions?
AMD Athlon X2 6000+ @ 3.3ghz
2gb Crucial Ballistix DDR2800
Biotstar T-force T560 A2+ (with Noctua NC-U6)
Evga 8800gts SSC (112sp) 640mb
2 x 50gb Quantum 10k SCSI (+ 100gb, 40gb ide)
CoolerMaster Extreme Power Duo 600w
Wrapped in a CoolerMaster CM690 with 7x120mm
Old February 21, 2008, 08:37 PM
llama_egg's Avatar
Level up: 28% Level up: 28% Level up: 28%
Level: 12 - 291 points to level up
I'm currently stable at 3510.6mhz, and I'm sure I can still get a bit more juice out of her yet. I would tell you what everything is set at, but I truthfully can't remember 100%, I'll mention it next time I restart. Also, I'm roughly 30/35°c when idle, and 40/45°c when under full load, mind you, I am water cooling!
Old February 22, 2008, 11:09 AM
kcksteve's Avatar
i managed to get the fsb to 220 stable vcore is plus 0.012 and chipset is at 3.00v is it okay to run it this high all the time? 3.3ghz ftw
AMD X2 6000+ vs Phenom 9550 lcdguy CPU's and Motherboards 6 February 26, 2008 01:01 PM
Overclocking Athlon 3800+ X2 vdf22 Overclocking, Tweaking and Benchmarking 5 February 7, 2008 02:25 PM
AMD Athlon X2 4600+ 334th_Frenchie CPU's and Motherboards 10 June 8, 2007 10:50 AM
6000+ overclocking results Misoprostol CPU's and Motherboards 11 April 9, 2007 01:27 PM
