Old October 3, 2011, 05:44 AM
Arinoth's Avatar
Originally Posted by ilya View Post
Processors are a lot more resilient than most people realize. Running at 1.32v vs 1.4v won't reduce the lifespan in any noticeable to the end user, most overclockers will have sold the chip or thrown it away well before the increased voltage has killed it. (as long as temps are under control) That's not to say pumping voltage to the limits is practical at all, increasing clock speed will increase heat and power consumption in a linear fashion. However, increasing voltage usually increases the two in an exponential fashion, so it's simply more practical to run at the lowest stable voltage for your target overclock.
Not quite linearly actually, as when you increase the amount of voltage going through the chip, you increase the amount of parasitic capacitance and inductance with the chip and its external pins (what we see). You get too much build up of this and it can kill a chip or cause clocks to be unstable.. That said its typically low enough that it's not noticeable unless its mapped over years of the chip, just saying that's the other reason.
Old October 3, 2011, 06:41 AM
Perineum's Avatar
Someone send me the the hardware and I'll make it fold for the team at whatever voltage we would agree on.....
Old October 3, 2011, 06:59 AM
Soultribunal's Avatar
The thing is though, with pushing the voltage so high you get diminishing returns on your overclock. To the point where 1.4 vs 1.53 will net you no appriciated gain giving the cooling sceme. Plus the higher the thermal load that isn't disipated (using the Noctua) the more electrical resistance. You start having to push beyond 1.53 on the board side to actually get 1.53 on the chip side , and that will stress any board out. Sure, the chip might not fail. But I bet you will start killing all the boards for no good reason.
I won't run my PSU beyond 80%, I would push my voltage to that threshold either out of personal preference.
ST
Old October 3, 2011, 07:20 AM
stoanee's Avatar
Seconded! Send your hardware to Peri.........
heatware
Old October 3, 2011, 07:57 AM
only 1.4v lol
my cpu needs 1.42v for 5.0 24/7
its not just the juice its in combination with the speed
some people been runing 1.5 for 6 months no degradation n some 1.4 n have degradation
i seen people pump in over 1.7v+ n the cpu still alive
i'm chicken i only pumped in 1.6v for some tests
if you cant keep her cool dont pump the volts
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old October 3, 2011, 08:02 AM
Voltage wussy? I was putting 1.49v through a e8600 back in the day.
Thing is now with chips like the Sandybridge using a lot of voltage is really unecessary unless your TRYING to blow up your chip or see its max potential. But most of us around here know that there is only so much benefit to overclocking before there isn't any more gains and that is when most of us stop.
Old October 3, 2011, 08:12 AM
There are a couple of other forums where this has been done, more than once. Suicide runs, peltier cooling, etc. Lots of reports of degradation, as in, 'my chip would run 5.1 (or 5.2 or 5.3) then I went for more and now it will only run 4.X'. It seems pretty rare that they run at 5.0 24/7, whether that is due to lack of cooling hardware or lack of how to knowledge. 4.8 24/7 is a lot more common, and a kazillion are being run at 4.5. The biggest source of data (that I have found) is overclock.net.
2600K @4.6 for now, still tweaking.
P8Z68-V Pro Gen3
Patriot Div2 Viper Extreme PC3-15000 4GBx2 (1866 9-11-9-27-2)
EVGA GTX 580 SSC
Caviar Black 1TB x2 RAID0
Corsair Gold 850W
Corsair H80
Corsair 600T Graphite
Old October 3, 2011, 08:56 AM
Dead Things's Avatar
This. As will all things overclocking, YMMV.
BTW, I *loved* the thread title!
Join the PPD revolution!
Proud to be Folding @ Home
deadthings @ Team 37412
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
  #19 (permalink)
Old October 3, 2011, 09:02 AM
yup lol
personally i go subzero for over 1.5v
so many of my cpus are good for 5.0+ stable i wonder how high op clockin lol
and how much gear he blew up lol
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
  #20 (permalink)
Old October 3, 2011, 09:05 AM
stoanee's Avatar
This man also loves drunken turtles.....uh huh.
heatware
help with ram voltage sempifer RAM 4 September 2, 2010 09:23 PM
Max VTT/IMC/QPI Voltage for P55? anthonee1230 Overclocking, Tweaking and Benchmarking 14 February 25, 2010 12:31 PM
Ram voltage 1.5 or 1.9 johnnyblazzwa RAM 21 January 25, 2010 03:48 PM
i5 750 voltage? Draex Overclocking, Tweaking and Benchmarking 11 December 31, 2009 06:04 AM
Max Voltage for i7 920 D0? bkh2 Overclocking, Tweaking and Benchmarking 23 December 22, 2009 12:41 PM
