<~----> Overclocking Help - Hardware Canucks
Old October 2, 2011, 06:00 PM
Trial Member
Default Overclocking Help
Ok guys I need some help overclocking my cpu here is a run down of my PC system build : Asus Crosshair Formal 4 motherboard, AMD 1090T 3.2Ghz, 8GB of Kingston Hyper X 1600Mhz ram, XFX Radeon 5770 HD, XFX 750 Watts Black Edition Power Supply, Corsair H70 and the coolermaster Master HAF X Case. Everything is running at stock speed right now maybe you can recommend some tips on how to overclock from here note I did not interfere with the bios as yet I was using the ROG Software. Thanks Guys
Overclocking Nub I7 940 C0/C1 IITSChiefII Overclocking, Tweaking and Benchmarking 0 August 7, 2011 08:44 AM
Overclocking my i7 930? bvsbutthd101 Overclocking, Tweaking and Benchmarking 14 September 15, 2010 06:50 AM
i3 530 overclocking fun Realityshift Overclocking, Tweaking and Benchmarking 11 May 29, 2010 04:40 PM
Needs some help overclocking lanken123 Overclocking, Tweaking and Benchmarking 0 April 21, 2009 11:51 AM
AMD Overclocking ?? cwestwell New Builds 16 October 20, 2008 01:39 PM
