-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   need help with i7 2600k + z68x-ud4 (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/46922-need-help-i7-2600k-z68x-ud4.html)
Your_friendly_gamer October 1, 2011 06:01 PM
I need help ocing this chip on this board. I also have gskill snimer 9-9-9-25 1600 mhz ddr3 ram 1.5v
I can simply just change the multiplier to 46 and disable auto boost and I can get it stable at 1.36v
However, I cant get it to 4.9 ghz, everytime I can get into windows but right away get a blue screen.
I am wondering what else should I turn off under the advanced cpu core features?
Thanks
PS. ZSAMZ_ I am looking at you!!!!!:bleh:
zsamz_ October 1, 2011 06:32 PM
i dont know how to overclock a 2600k:rofl::rofl::rofl:
Your_friendly_gamer October 1, 2011 06:36 PM
come on, please help me with the settings, you are like the master guru. I know that! pleaseeeeeeeee:sad:
zsamz_ October 1, 2011 06:45 PM
what revision is the ram
ennable cpu internal pll overvoltage
many 2600k wont do 4.9;) n need over 1.5v
dissable c1 c3 n energy saving crap
load latest bios
use llc 5 or 7
Your_friendly_gamer October 1, 2011 06:53 PM
Yea i am at work right now, but before coming here today, I did install the latest bios, even tho it was beta. Here are the specs on ram:
CAS Latency9-9-9-24-2NCapacity8GB (4GB x2)SpeedDDR3-1600 (PC3 12800)Test Voltage1.5 VoltsPCB
Registered/UnbufferedUnbufferedError CheckingNon-ECCType240-pin DIMMWarrantyLifetime
My temps at 1.36 are amazing tho. I idle in the 20's and with LinX I stay under 60. It maybe because I may have a sick Megha with two blade master fans in push pull config.
I am gonna try that, I am gonna disable some other stuff. I believe I tried 4.8 at1.4 it did boot up and stuff, it looked very beautiful and then when I ran LinX it froze and then bsod on me.
Thanks Zsamz_ you are always a great help and I alway apperciate your advise!:clap::canadianwave:
zsamz_ October 1, 2011 08:09 PM
i know the specs of the ram
what is rev.#
Your_friendly_gamer October 1, 2011 09:33 PM
I opened my case and took the ram out and couldnt find the rev #, how, or where can I locate it?
zsamz_ October 2, 2011 11:13 AM
oops thought your ram was corsair lol
bump the vdim to 1.55v
your ram might even do 1866 :whistle: if it has hynix chips
Your_friendly_gamer October 2, 2011 11:02 PM
Zsamz_ yes sirry you are the MAN, 1.55v for ram did the trick, turned off everything else, and boom at 1.4v check it sir!
CPU-Z Validator 3.1
Thank you so much, I saved this on cmos for benches but everyday use and for folding i am gonna keep it 4.5ghz.
Thank you again.
yycraven October 2, 2011 11:43 PM
Nice OCing on that 2600K.
