Old September 27, 2011, 10:40 PM
Default can I flash the BIOS of my GPU?
After buying my GPU, GTX560 TI CU II yesterday I thought I was getting the TOP version. Now That I know there is two GPU's that look Identical, Have the same extra special parts, Same cooler, Paint, Everything except the 900Mhz Core clock out of the box.
So is there anyway to flash my BIOS with the ASUS TOP version so I also have the 900Mhz without overclocking??
I know I could just stick to Overclocking it myself, But I am wondering if the TOP's BIOS has better MEM timings or other settings that help it achiev the 900Mhz out of the box?
What are your thoughts guys??
System spec: Intel i7 2600k, Gigabyte GTX 570 Super Overclock, Kingston DDR3 2X4 GB sticks, ASUS P8P67 PRO, Cooler Master 700 watt PSU, 750GB*2 Sata,SATA III 1TB HDD Acer 24 Widescreen, Antec 300, Windows 7 Ultimate 64 Bit
Old September 27, 2011, 10:49 PM
supaflyx3's Avatar
I don't see why you wouldn't just overclock it yourself, it should reach 900 and even 1Ghz no problem at all.. although it probably is possible.
Old September 28, 2011, 03:59 AM
GT7R's Avatar
Yes you can, simply download and install it.
ASUSTeK Computer Inc. - Graphics Cards- ASUS ENGTX560 Ti DCII TOP/2DI/1GD5
Old September 28, 2011, 07:41 AM
You'd be best to overclock it first to see what the card can actually do before doing a bios upgrade and getting a unstable card.
BIOS Flash AmuseMe Troubleshooting 9 September 18, 2009 07:07 AM
ATI BIOS FLASH 3870 x 2 Shredder Guides & How-to's 0 March 31, 2009 11:06 AM
how do you flash the bios on a gpu? Gameplaywarrior Guides & How-to's 8 October 20, 2008 04:41 PM
Help with bios hot flash ebdoradz CPU's and Motherboards 0 February 7, 2008 10:52 AM
Bios Flash, Please Help !! Unklmo Troubleshooting 5 October 22, 2007 04:55 PM
