Old September 29, 2011, 09:58 PM
Supergrover's Avatar
Originally Posted by bushwickbill View Post
I wonder if re-seating the cooler or something would help with temps? I think 80C is way to high for this kind of GPU cooler!! I hit 940Mhz last night, And it was OCCT stable with no errors. But man the temps were high. No voltage increase, Except it seemed that the voltage went up a small margin on its own once i passed the 920Mhz mark.
Anyone have any other ideas as to why its running so hot under load? When I am idling at deaktop temps are 32C.
I have 2x 6970 with the DCII cooler, I had to reseat the cooler on one card since it had both crappy contact (damn cards are heavy) and way crappy tim contact.
Reseated and dropped 20c under load.
R.I.P.
