Old September 27, 2011, 02:30 PM
Based on the CPU support, the top model would be a Phenom II X3 715. But as I said, it doesn't make sense to me that this is the only Phenom II CPU that the mobo supports.
Old September 27, 2011, 03:26 PM
On2wheels's Avatar
I think what was shying me away from trying to o/c was the different screens in the bios. I'm not using that pc now, but from the manual, there's some auto/manual voltage settings, some ram settings, FSB speed, and I don't know which is the easiest, safest way to go. I don't want to go crazy, and I'm not interested in having the cpu fan screaming 24/7.
Is there a guide/walkthrough on what changes to make first?
Old September 27, 2011, 03:39 PM
Silvgearx's Avatar
The support for x3 715 is still in beta stage. It is best to use what is supported for beginners.
BFBC2 online noobie suggestions Prolab Gaming 22 March 12, 2011 09:45 PM
Really Noobie Question ? JORD4N Storage 2 September 8, 2009 05:24 PM
F@H noobie punk_zappa HardwareCanucks F@H Team 4 March 21, 2009 12:42 PM
HTPC Noobie Seeks Advice dadzilla HTPC Systems & Software 3 October 2, 2008 03:32 PM
AMD prepares its Phenom FX, Phenom X4 and Phenom X2 lineups Babrbarossa Press Releases & Tech News 1 May 4, 2007 07:38 AM
