Old September 23, 2011, 12:37 PM
lechumbl's Avatar
Hi Supergrover,
For you as a gamer, I see exactly what you are saying.
For me, as I do not game at all, it is not necessary for me to have clocks above 3700, as that is the minimum for the -bigadv to fully function, points wise.
Take care......
Regards,
Lee
* F@H Unit Points *
Old September 25, 2011, 04:21 PM
lechumbl's Avatar
Hi all,
OK, I answered my own question, with a little more investigation.
When I take my 3066 MHZ CPU six core Xeon and O/C it to 3700 to meet the requirements of the -bigadv, the PPD or times per frame are not too great a difference.
I have O/C'd my CPU to 4005, and the difference is major.
Conclusion, O/C the hell out of it, who cares, and as was once wisely stated, "Cause I can!!"
Take care, and O/C away......
Regards,
Lee
* F@H Unit Points *
Old September 25, 2011, 04:34 PM
Sagath's Avatar
Glad to hear you went big or went home ;)
You're right that the Overclock doesnt scale well. However, a TPF of a couple seconds is probably not that big a deal because you're just inside the deadline with your projects at 3.7ghz. The points value for F@H bigadv units is not linear, so even a couple seconds per frame can add up quite quickly in PPD totals.
Besides, the likelyhood is any 'damage' you're doing to shorten the life of your Xeon probably wont matter in the scope of how long you'll actually use the computer functionally. Ive never heard of anyone on these forums having a CPU burn out off overclocking that could be confirmed it was because of the OC and not a bad chip that needed RMA anyways..
Old September 25, 2011, 04:39 PM
lechumbl's Avatar
Hi Sagath,
Spot on!!
Gunna fry eggs on my video cards before I do on my CPU.
Take care.........
Whos pic in your avatar?
Regards,
Lee
* F@H Unit Points *
difference between MCB 655-b vs MCB 655-01 hatabilly0204 Water Cooling 8 April 25, 2010 11:44 AM
Wow, What a difference! Cowboy Video Cards 14 January 18, 2010 04:02 AM
is there a difference gingerbee O/S's, Drivers & General Software 0 December 9, 2009 10:44 AM
What is the difference? akbg Storage 5 October 16, 2008 04:51 PM
Wow.. Big difference Infiniti Water Cooling 8 December 25, 2007 08:24 PM
