Old September 10, 2011, 02:29 PM
Default Overclocking Problems -- HELP!!!
Hello group,
I followed this YOUTUBE.com video to the letter.
I was able to get to 5.0Ghz for my CPU.
However, for the RAM the highest I can go is 1600Mhz!! I have new RAM that can go at 2133Mhz.
So, why will the BIOS not accept a higher level of RAM ??
In the video he wimped out and used 1866Mhz, but I cannot even get that!!
So what is wrong here?
Thank you,
CG :)
Old September 11, 2011, 01:50 AM
you can check for a newer BIOS maybe? I'm not sure.
In the meantime you can tighten the timings to compensate.
Overclocking problems... NexRedshirt Troubleshooting 4 October 31, 2009 11:18 AM
E3110 Overclocking problems jnliten Overclocking, Tweaking and Benchmarking 2 April 7, 2008 04:30 PM
Problems with Overclocking my e8400 Tumdace Overclocking, Tweaking and Benchmarking 66 March 12, 2008 01:44 AM
Problems Overclocking with Gigabyte GA-P35-DS3L DukeNukem Overclocking, Tweaking and Benchmarking 8 December 13, 2007 05:35 PM
Problems Overclocking. Dethredic Video Cards 6 November 3, 2007 07:06 AM
