<~----> DP45SG ram timings - Hardware Canucks
Old August 31, 2011, 01:17 PM
Tokizak's Avatar
Trial Member
Default DP45SG ram timings
I've done alot of reasearch in order to fix the problem, which is; my ram is 1333mhz 7-7-7-21 1.5v (2x 2g), and clocks to 1066mhz at 8-8-8- 24 1.55v. It gives me windows experience index rating of 5.5 and not alot of the info on CPU-Z lines up with what it should be. (i'll include the report). after much tweaking and retrying, as there are very few actual combinations that will post, but set manually, i have it seemingly stable at 7-7-7-21 1.7v (as far as the bios settings are set), But i still get a 5.5 WEI rating (all others above 7). also it shows me on the system page, that i have 2.74g usable out of 4g total. (see below my name for my complete computer specs.)
CPU-Z TXT Report
Binaries
CPU-Z version 1.58
Processors
Number of processors 1
Number of threads 4
APICs
Processor 0
-- Core 0
-- Thread 0 0
-- Core 1
-- Thread 0 1
-- Core 2
-- Thread 0 2
-- Core 3
-- Thread 0 3
Processors Information
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name Intel Core 2 Quad Q6700
Codename Kentsfield
Specification Genuine Intel(R) CPU @ 2.66GHz (Engineering Sample)
Package (platform ID) Socket 775 LGA (0x4)
CPUID 6.F.4
Extended CPUID 6.F
Core Stepping B0
Technology 65 nm
Core Speed 2660.2 MHz
Multiplier x FSB 10.0 x 266.0 MHz
Rated Bus speed 1064.1 MHz
Stock frequency 2666 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T, VT-x
L1 Data cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 4 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2 x 4096 KBytes, 16-way set associative, 64-byte line size
FID/VID Control no
Northbridge Intel P45/P43/G45/G43 rev. A3
Southbridge Intel 82801JR (ICH10R) rev. 00
Graphic Interface PCI-Express
PCI-E Link Width x8
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 4096 MBytes
Channels Dual, (Symmetric)
Memory Frequency 532.0 MHz (1:2)
CAS# latency (CL) 7.0
RAS# to CAS# delay (tRCD) 7
RAS# Precharge (tRP) 7
Cycle Time (tRAS) 21
Row Refresh Cycle Time (tRFC) 63
Command Rate (CR) 2T
MCHBAR I/O Base address 0x0FED14000
MCHBAR I/O Size 4096
Memory SPD
DIMM # 1
SMBus address 0x50
Memory type DDR3
Module format UDIMM
Manufacturer (ID) G.Skill (7F7F7F7FCD000000)
Size 2048 MBytes
Max bandwidth PC3-10700H (667 MHz)
Part number F3-10666CL7-2GBRH
Number of banks 8
Nominal Voltage 1.50 Volts
EPP no
XMP yes
XMP revision 1.1
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 6.0-6-6-16-22 @ 444 MHz
JEDEC #2 7.0-7-7-19-26 @ 518 MHz
JEDEC #3 8.0-8-8-22-30 @ 592 MHz
JEDEC #4 9.0-9-9-24-33 @ 666 MHz
XMP profile XMP-1334
Specification PC3-10700
Voltage level 1.500 Volts
Min Cycle time 1.500 ns (667 MHz)
Min tRP 10.00 ns
Min tRCD 10.00 ns
Min tWR 15.00 ns
Min tRAS 31.50 ns
Min tRC 45.00 ns
Min tRFC 90.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
Command Rate 2T
XMP timings table CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
XMP #1 7.0-7-7-23-32-2T @ 700 MHz (1.500 Volts)
DIMM # 2
SMBus address 0x52
Memory type DDR3
Module format UDIMM
Size 2048 MBytes
Number of banks 8
EPP no
XMP yes
XMP revision 1.1
Min tRP 10.00 ns
Min tRCD 10.00 ns
Min tWR 15.00 ns
Min tRAS 31.50 ns
Min tRC 45.00 ns
Min tRFC 90.00 ns
Min tRTP 7.50 ns
Min tRRD 6.00 ns
Command Rate 2T
Any help on this would be greatly appreciated, If more information is needed, I can post the whole report, (just didn't wanna make it to spammy)
-Toki
RAM timings and voltage Maplicito RAM 17 May 20, 2010 09:26 PM
RAM timings... little help please. somecanadianguy RAM 3 November 19, 2009 06:14 PM
[FS] Cheap dp45sg 2x2gb ddr3 Cheap nvidiaslayer Buy/Sell & Trade 1 February 21, 2009 06:43 AM
What do the 2T mean in some ram timings Gameplaywarrior RAM 2 October 17, 2008 04:24 AM
timings vs. speed Mr. Cipher RAM 22 February 15, 2008 04:07 PM
