Old August 18, 2011, 10:01 AM
Painbringer71's Avatar
Default Need a little help with overclocking
Phenom II x 4 945 Denab 3.0
ASUS M4A78T-E
1333 DDR3 Rip jaws 8 gig
6850 sapphire toxic x 2 Crossfire (these are factory over clocked)
Eyefinity setup VH242H x 3 23.6” of eye pleasure
WD black 640 Gig HD
Win 7 64 bit
When I set up my build I figured at the time that a x4 3.0 is good enough. Well I have a feeling its bottlenecking my system.
I am a noob to overclocking.
I have the AMD Overdrive Utility software that came with the board that basically can overclock for you. I have run the autoclock program and it ramped my system to 3.2. I ran it like this for the night. My 3dmark11 score was brought me up from below normal to a normal score for simuliar setups, and the system seemed much faster. So I saved the settings in the software and shut down for the night. When I turned it back on it was back to 3.0. The 945 is a locked multiplier so I guess there is no huge over clocking that can be done but since I was able to get it to 3.2 with software.
Question 1 does anyone know haw to save the settings so the system runs at it from startup? I can not even find what I saved from before so it looks like I have to Auto clock it every time I want it. And no I do not keep my system running when I am gone. (Probably should but I don’t)
Question 2 Looking for NOOB instructions on what to do to the Bios to overclocking (my board has a review on this site if you need details) 3.2 or a little higher is all I am looking for I really do not want to burn anything out.
My rip jaws are Bios defaulted currently but are capable of 7-7-7-21
I have the factory CPU cooler with factory paste ~ I have never had an issue with it
PS I also have a software called Turbo V But I am tentative to touch settings since I do not know what it can do~ I am a noob and have never touched this program.
Again I am a Noob and will need a step by step this is
Thanks in advance
Painbringer 71
Old August 18, 2011, 10:25 AM
Shadowmeph's Avatar
there is a setting on the auto overclock ( I think on the left hand side) that you can click on that will save your overclock setting so that when you reboot it will load those settings
Overclocking my i7 930? bvsbutthd101 Overclocking, Tweaking and Benchmarking 14 September 15, 2010 06:50 AM
i7-860 Overclocking anthonee1230 Overclocking, Tweaking and Benchmarking 6 November 28, 2009 05:09 AM
Overclocking HELP please Crysisfan11 Overclocking, Tweaking and Benchmarking 1 May 27, 2009 10:15 AM
Overclocking CPU DavidDemise Overclocking, Tweaking and Benchmarking 4 July 29, 2008 07:18 PM
Need some help on Overclocking ShinseiKen CPU's and Motherboards 10 July 11, 2007 07:41 PM
