Old August 7, 2011, 08:44 AM
IITSChiefII's Avatar
Default Overclocking Nub I7 940 C0/C1
hey,
Im total nub in overclocking. I just rebuilt my pc new chassis and a good watercooling loop. im looking to overclock now, ive read several guides and scowered the forums the past week, and for the past couple days been trying to get a stable clock.
Ram has XMP but I read its better to set manual and put the settings in so thats what I did
9-9-9-28 2N (rated for) its 3x2GB triple channel kit
Dram Freq set to 1570Mhz (1600mhz rated for)
Its stable atm in all 3 prime tests any lower voltage in Vcore or QPI/Dram will cause a bsod after 30mins
Tubomode Disable
Speedstep Enabled
HT Enabled
Just updated P6T Deluxe v1 Bios to latest (2209) it unlocked 23x multi. (was capped at 22x before)
I7 940 3611 Mhz
23x157
Vcore 1.25000v (1.24 unstable)
PLL 1.8v
QPI/DRAM 1.31250v (1.30625v unstable)
Dram bus voltage 1.5v (ram is rated for 1.5v at 1600mhz)
everything else not listed here is set to auto/default
Temps under prime 58-64c
So are these safe settings am I over looking something? should I push for more and is it worth it?
Advice/Recommendations for a nub? Kieli New Builds 56 December 17, 2010 02:54 AM
i7 940 help VDubbAz Overclocking, Tweaking and Benchmarking 6 July 10, 2010 09:36 PM
I'm a Watercooling Nub. Help plox? Beastylemon Water Cooling 3 December 13, 2009 05:19 PM
Overclocking a Phenom II 940 AmuseMe Overclocking, Tweaking and Benchmarking 7 June 17, 2009 08:19 AM
Nub Water Cooling setup? thatguy Water Cooling 11 May 23, 2008 04:15 PM
