  #21 (permalink)
Old August 6, 2011, 12:06 PM
I turned the OC off, went back to stock clock, the temps used to be 19-22 at idle but now they're higher.. why is that? Could it be that I moved and where I was before I had AC 24/7 on?
  #22 (permalink)
Old August 6, 2011, 12:31 PM
Lima's Avatar
I would have to say yes, that is most likely what is going on.
  #23 (permalink)
Old August 6, 2011, 01:28 PM
leave it on silent,then.
why go back to stock? :)
edit : leave smp running while not in use,that little bugger at 4 gigs something will output quite a bit
  #24 (permalink)
Old August 6, 2011, 06:33 PM
Back to stock because where I moved I don't know yet what's their home-wattage and if I could use as much power as I wanted.. and also I live in a very hot place and the heat from the computer was making it worse, lol.. in winter I'll have more fun with it. :P
MSI 560 Hawk vs GB 560 SOC vs MSI 6950 TF3 -Clive- Video Cards 13 June 16, 2011 11:51 AM
Stable OC? ADay2Long Overclocking, Tweaking and Benchmarking 18 February 16, 2010 04:59 PM
Stable OC no longer stable? Arinoth Overclocking, Tweaking and Benchmarking 17 December 1, 2009 09:00 PM
4 Ghz stable(?) bkh2 Overclocking, Tweaking and Benchmarking 20 August 24, 2009 05:20 AM
I7 Stable @ 3.81 Ghz rjbarker Overclocking, Tweaking and Benchmarking 17 March 10, 2009 11:37 PM
