Old August 3, 2011, 10:08 AM
no worries. well it varies from chippie to chippie so you wont get to 4.4 for sure lol.
3dmark stresses the system further and simulates gaming under stress(aka a good thing)
Old August 3, 2011, 11:05 AM
I'm quite sure the 560 is more overclockable than the 530, and after 5 hours of prime95 the max temp is 50 at 4.2Ghz, so, I'd say still plenty of room to play with
Old August 3, 2011, 11:08 AM
bump up the 'fsb' to 182 and see what gives.
Old August 3, 2011, 12:42 PM
I'll try tomorrow I won't be able to see how it behaves tonight and I'd rather be at home paying attention to it lol
Old August 3, 2011, 12:53 PM
*puts on the sound of chickens.
cool. as long as you watch the juice,meaning stay clear of 1.5+ volts if you run it fanless or very low rpms on the fan, you should be fine.
Old August 3, 2011, 09:10 PM
UPDATE: After 2 hours of Prime95 and 2 runs of 3D Mark 11 the max temp I reached was 55°C..
(To me it's impressive, I was used to the i3 530 on stock cooler which was regurarly on 50-51°C in full load, at 2.93Ghz, and now I'm getting pretty much the same temps, but on a 4.15Ghz overclock)
Should I keep going with the OC?
Old August 3, 2011, 09:30 PM
nice.
first of all set the fan to hat you like not hearing
then work your overclock.
answer being : yes,of folding course!
Old August 4, 2011, 05:57 AM
nice.
4.4Ghz now, temps are about 56-57.. I guess I'm nearly reaching the limits
  #19 (permalink)
Old August 4, 2011, 09:19 AM
very good. what rpms did you set the fan to again?
since you have a good cooler you can actually chose hehe
  #20 (permalink)
Old August 4, 2011, 01:40 PM
On the motherboard I have 3 profiles for the fan, silent standard and turbo.. i'm on standard lol
MSI 560 Hawk vs GB 560 SOC vs MSI 6950 TF3 -Clive- Video Cards 13 June 16, 2011 11:51 AM
Stable OC? ADay2Long Overclocking, Tweaking and Benchmarking 18 February 16, 2010 03:59 PM
Stable OC no longer stable? Arinoth Overclocking, Tweaking and Benchmarking 17 December 1, 2009 08:00 PM
4 Ghz stable(?) bkh2 Overclocking, Tweaking and Benchmarking 20 August 24, 2009 05:20 AM
I7 Stable @ 3.81 Ghz rjbarker Overclocking, Tweaking and Benchmarking 17 March 10, 2009 11:37 PM
