-   Overclocking, Tweaking and Benchmarking (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/)
-   -   How do I overclock my watercooled gtx285 vid card :-} (http://www.hardwarecanucks.com/forum/overclocking-tweaking-benchmarking/45273-how-do-i-overclock-my-watercooled-gtx285-vid-card.html)
Shadowmeph July 30, 2011 09:50 AM
Finally after 4 months of having this water cooled gtx285 vid card sitting around I decided to install it, now I am embarrassed to admit that I am not sure how to do a stable overclock on this thing I want to over clock this card as high and as stable as possible then I can retry folding again
_dangtx_ July 30, 2011 09:57 AM
easy. open up furmark and let it rip
then use precision to up clocks slowly,starting with shaders.
dont touch ram.
lowfat July 30, 2011 10:07 AM
This my old card? Well I definitely can't remember what clocks I had with it. But I'd just run Unigine Heaven for 10-15 minutes at a clock. If it works. Increase the core clock. Rinse. Repeat.
JD July 30, 2011 10:18 AM
I personally use MSI AfterBurner (to set the OC) + Kombustor (to test). Nice little suite that integrates with one another.
Shadowmeph July 30, 2011 10:46 AM
I think that it is your old card .
so I should use precision to verclock ? how much to raise the levels before each test?
_dangtx_ July 30, 2011 10:54 AM
run furmark while raising.
dont stop it
Shadowmeph July 30, 2011 11:59 AM
ok what am I looking for becasue I have maxed out the Precision shaders and my temps are around 47
_dangtx_ July 30, 2011 01:38 PM
ok and it can loop 3dmark and what not without issues?
Shadowmeph July 30, 2011 05:14 PM
no issues I can see
zsamz_ July 30, 2011 05:31 PM
no voltage control
you gonna need pencil mod to go beyond 750mhz
