  #41 (permalink)
Old February 8, 2008, 05:28 PM
3.0charlie's Avatar
Sorry, don't know them. I know if I'm really stuck, Home Depot - Rona - Reno-Depot - Home Hardware all carry some tubing.
  #42 (permalink)
Old February 8, 2008, 07:47 PM
Woot! got it all back up and running, and its um... like 2 degrees cooler lol, well... better something than nothing anyway ;)
vista 64 on these rigs
Q9450 @ 3.5Ghz | E8400 @ 4.2Ghz
8gb Muskin Redline. | 2gb Kingston Hyperx
________________________________|_________________ ______________
EVGA 780i FTW ----\--||___||--/---- EVGA 780i SLI
Antec TP Quatro 1000W \ :==^==: / Antec TP Quatro 850W.
Nvidia 9800 GX2 X 2 SLI \|--o--|/ Nvidia 8800 GTS X 2 SLI
1X 500GB Western Digital. \_____/ 3X 150GB WD RAPTOR RAID-0
  #43 (permalink)
Old February 8, 2008, 07:50 PM
3.0charlie's Avatar
What loop did you do? And how many rads, fans?
  #44 (permalink)
Old February 8, 2008, 08:07 PM
resivior, pump, dual rad with 2 fans, triple rad with 3 fans, cpu block, resivior
  #45 (permalink)
Old February 8, 2008, 08:12 PM
3.0charlie's Avatar
Good, that's a loop.
Next step would be to change those fans. Have you tried using 2 of the triple rad fans, and installing those in push/pull config on the dual rad? It may be interesting to see the difference.
  #46 (permalink)
Old February 8, 2008, 09:29 PM
no change in temps putting them push pull on the double. meby if i got better fans in push pull on both rads... :D would be damn expensive for no gain if it didnt work lol... well, only one way to be sure. lol, soon as i have some money to waste i'll order 8 yate loons and see how they run.
  #47 (permalink)
Old February 18, 2008, 03:28 PM
biff's Avatar
Originally Posted by enaberif View Post
Nothing else? I thought you'd want to add some additives to that or do you change so often nothing builds up hahaha
I add about 10% to 15% glycol to de-ionized water. Glycol is a poison (make note of that!) so it will keep all the nasties at bay. Other side benefits are corrosion resistance and it has a touch of lube in it meant for lubricating the water pump in your car, I can't see it being any different for our little pumps and if you buy a little concentrated jug it will make A LOT of "computer coolant" so it's pretty cheap.
I'm sure 100% distilled would be fine on its own but I figure why not. I've read that a touch of RedLine Water Wetter will help reduce tmps by a degree or two but I've never tried it as I've heard that if you add too much it will make a bunch of stringy stuff in your loop.
Q6600 @ 3.83GHz w/ D-Tek Fusion
Asus P5Q-PRO
2x 2GB PC8000 Mushkin Redlines @ 1020MHz w/5-5-5-12 timings
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Cooler Master Cosmos on water
  #48 (permalink)
Old February 18, 2008, 04:13 PM
MpG's Avatar
MpG MpG is offline
The problem is that Glycol doesn't hold or conduct heat as well as water does. Certainly, it's cheaper, but only if you actually need it all. Otherwise, there's other, reasonably-priced, stuff that does a better job without giving up any performance.
And yes, Water wetter has trouble staying in solution at cooler temperatures. There are equivalents that are better for PC water cooling systems, although I can't think of their names off-hand. Some additives include them in small quantities - usually the ones that claim "improved performance".
Water Cooling How To?? e_1337 Water Cooling 5 March 16, 2008 01:00 PM
Water cooling question Infiniti Water Cooling 11 December 26, 2007 11:11 AM
Water cooling kit Vinnie Water Cooling 5 November 12, 2007 09:22 PM
Another DIY Water Cooling Rig Magnesious Water Cooling 5 April 14, 2007 11:51 AM
Overclock3D on Fluid XP+ HP watercooling fluid Supergrover Reviews & Articles from the Web 0 January 15, 2007 05:08 PM
