Old July 17, 2011, 10:45 AM
Supergrover's Avatar
Work one thing at a time, as you have done drop the ram down to stock or below stock, that way you rule it out of the equation. Find the cpu's limit then start working on ram.
Right now you are shooting in the dark you dont know if your memory is good with the settings, as I posted in the thread earlier read the guide, it will show you a detailed step by step way to overclock your AMD system.
R.I.P.
Old July 17, 2011, 04:59 PM
Sorry Missed that link .. got it now thanks.
You are right diffidently right shooting in the dark... going from auto on up. But I will be printing this off and studying it at work tonight again thanks
Old August 7, 2011, 11:24 AM
Just wanted to give an up date...
It seems the BSOD code of 0x00000124, could possibly be a voltage issue. Googling seem a few people out there seem to have the same issue, where no matter how little OC ya do, it will eventually freak out. Mobo is not regulating the power correctly .. or bad transistors.
It was mentioned to here to bump the Vcore volts, not sure if I have that setting in the BIOS, but will dig around some more.
OC for Chimp Challenge xilocient Overclocking, Tweaking and Benchmarking 2 May 10, 2011 03:23 PM
Today's Challenge! _dangtx_ Off Topic 3 June 11, 2010 09:19 PM
Build Challenge fearm3now New Builds 6 May 3, 2010 08:51 PM
GIGABYTE and Futuremark Host P55 OverclocKing Challenge and 10K Challenge Gav Press Releases & Tech News 1 November 13, 2009 02:31 PM
Challenge CactusJoe New Builds 11 December 2, 2008 06:43 PM
