Rookie OC question /embarassed
hey, so I just built the following:
P8Z68V-PRO Mobo
i5 2500K Proc
8GB DDR3 Vengeance RAM
Corsair H50 water cooler
500GB Sata HDD
2TB Sata3 HDD
700W PSU
Radeon 5830 (will be upgraded after i have more cash)
that should cover what you need to help me. Anyways, I have no idea how to overclock it properly. I went into the BIOS and set it to extreme but I don't get alot of performance results (it caps at 3.4) and it tends to hike my CPU core temps by ALOT. (I'm using Core Temp + widget to monitor)
The case has 2 120mm fans on high setting (I'm not sure of the rpm on them, they're stock in the Antec 900 case)
and a 200mm in the top, also set to high speed
the back fan mounted to the H50 rad is also set to high speed
how can I stably OC to about 4 or 4.2? and not send my temps through the roof?
currently at the 3.4 it runs idle around 32 degrees, under load around 37-43, and under heavier load around 55-60.
Here's a strange occurance that might help or confuse anyone reading this.
Last night I ran Chrome, Steam, Divinity 2, Heroes 5, Winamp, Utorrent, and Catalyst. While running all this the system was averaging around 37 to 42 degrees on each core. here's the kicker, when I shut down Divinity 2 and Heroes 5 (I was running both as an experiment, I'd OC'd the vid card/fan using Catalyst), I then turned on Dungeon Seige 3. the temps ALL spiked to 58-60 degrees.
I've tested it using Borderlands, Magic 2012, WoW and I'm a frequent multi-tasker of HD movies/audio while photoshop/surfing/gaming. The temperatures during all that has never exceeded 45 degrees.
Any ideas? I dont think DS3 is THAT much of a hog on the specs, and my comp build should be able to crush it.
help?
