Old July 1, 2011, 11:13 PM
Default need help with 1090t overclock
hello, im trying to oc my 1090 to 4ghz and i keep running into bsod's with in the first few minutes of prime 95
system is 1090t on a c4f mobo, 8gigs, corsair dominator ram, 1600 mhz @ 6-8-6-24 t2
cup ratio: 20.0
CPU bus freq: 200
cpu\nb freq: 2800
ht link: 2600
cpu pwm : auto
CPU LLC: auto
Cpu/nb llc : auto
cpu volt: 1.4
cpu/nb volt : 1.51
is there any more info you need or anything im doing wrong?
Old July 1, 2011, 11:22 PM
drop htt bus by 1
creek up slowly and see which one lasts longer(work the multi only)
drop your ltd a bit
not sure all can do 4 gigs on such low(1.4) voltage ;)
and welcome aboard!
Old July 1, 2011, 11:31 PM
have to excuse me for my ignorence of accronyms, still new to overclocking.
ITD?
and how much more should i bump up the voltage?
and thanks :P
Old July 2, 2011, 12:01 AM
Silvgearx's Avatar
I think it is a ram problem.
6-8-6 is asking too much, set it back to default 8-8-8
And that CPU NB volts seems high. Try to stay under 1.4V
You most likely need 1.45v ish to hit 4ghz
Drop your HT link from 13 -> 12 is what dan meant.
Old July 6, 2011, 02:48 PM
cup ratio: 20.0
CPU bus freq: 200
cpu\nb freq: 2800
ht link: 2600
cpu pwm : auto
CPU LLC: auto
Cpu/nb llc : auto
cpu volt: 1.4
cpu/nb volt : 1.51
Hello user whom is a 1/2 hour away from me.
I own the chip & i got 4 ghz easy by doin as you have listed accept as follows:
cup ratio: 20.0
CPU bus freq: 200
cpu\nb freq: 2400
ht link: 2600
cpu pwm : auto
CPU LLC: auto
Cpu/nb llc : auto
cpu volt: 1.45
cpu/nb volt : 1.41
You will need at least 1.45v on the cpu cores themselves, default the rest of your settings, then once your multi is set to 20x work on your cpu/nb frequency bumping it up till its not stable. thats how I have mine as seen in the following pics:
Hope that helps you some.
Old July 23, 2011, 12:56 PM
Well ?
Old October 4, 2011, 06:04 PM
MARSTG's Avatar
can you reach 4 GHz stable with the stock cpu cooler?
Old October 4, 2011, 07:13 PM
supaflyx3's Avatar
I would say no... :l
Old October 4, 2011, 08:05 PM
techman95's Avatar
not possible unless your in an industrial freezer, at stock my 1090 was at 40c idle and 60c load it was terrible but now with my v6 on there it idles at 27c and load in the 40's to 50's depending on ambient
Old October 7, 2011, 01:58 PM
uwish's Avatar
I am stable @ 4 Ghz, all I did was up my CPU ratio (done in windows with the ASUS M5A99X MB) to 17 and then upped my core voltage to 1.38125. Runs fine with Venomous X RT CPU cooler.
Not having any stability issues here. I keep my bus speed the same that way I don't have to worry about my 1333 RAM.
AMD 1090T @ 4Ghz
Thermalright Venomous X RT cooler
AMD M5A99X EVO MB
4GB DDR3 RAM
XFX Radeon 6870
Coolermaster Haf X case
>3 TB storage
dual Samsung 22" widescreens
[FS] AMD 1090T FrankyG Buy/Sell & Trade 2 November 10, 2010 09:04 AM
Amd 1090t at 4ghz LacrosseTown Overclocking, Tweaking and Benchmarking 3 August 15, 2010 07:52 PM
Help selecting a cooler for my 1090t unicorn11 Water Cooling 8 June 29, 2010 06:42 AM
1090t goes out after 12 hours LacrosseTown Troubleshooting 12 June 21, 2010 05:36 PM
X6 1090T Thuban Build sswilson Case Mods, Worklog & Gallery 78 May 31, 2010 04:13 PM
