Originally Posted by MpG To a point. After all, water cooling involves several instances of thermal transfer, before the heat finally reaches the air. |
Not quite. If you think of thermal transfers like electrical circuits then what enaberif was planning more of a series-circuit type setup, with heat being exchanged as i showed before Cpu -> paste -> copper -> paste -> ultra 120.
On the other hand, a water cooling setup is more like a parallel circuit in terms of thermal transfers. True the water does flow to every component one in a row but the water has some chance to cool in the tubing before going to the next component and so on. Also, a watercooling setup can be branched in a "Y" system that even more resembles a parallel circuit.
Ex: Water -\---> Cpu --------------> NB -------/> Rad
.................\-->Video card 1 -> Video card 2--/
