Old June 22, 2011, 12:03 PM
Fudd Rucker's Avatar
Default A6-3400m overclocking
Ordered a cheap laptop for work and its got An a6-3400m with a 6250 gpu onboard. Now my employeris a stickler for old ass specs and won't budge on them. They require a 3ghz cpu (p4/celeron lol) and fail to understand multicore processing or modern architwcture. Is it possible to clock 2 cores to 3ghz via AOD and shut 2 cores off.
I couldnt think of something snarky or interesting to put here this time around.
Old June 22, 2011, 03:00 PM
If they really know that little just tell them it is 3.0 ghz... Overclocking laptops is not recommended even if you disable two cores because the other two cores will still be way too hot.
I wouldn't bump it much past a 200 mhz overclock.
Also why not just explain to them that this computer's processor will be much much faster?
Old July 9, 2011, 02:37 PM
Trial Member
Default how to deal with b.s. admin
OP
What are you talking about? I don't understand the problem here.
You have a 6.4 GHz processor so you have complied with the 3GHz minimum. (When all four cores are on continuously they are @ 1.6GHz.)
If you fill out any paperwork that's how you should write it up.
Old July 10, 2011, 10:58 AM
Is this about a program that won't start if it detects clock speeds are too low? You don't want to overclock anything just for something like that - a laptop is usually not overclockable and even if you find a way you won't be able to get more than 10% or so without making something unstable. Trick the dumb software if possible.
If this is about dumb management, then continue telling them to buy Pentium D processors
Overclocking help please Stubby Overclocking, Tweaking and Benchmarking 6 December 30, 2010 10:06 PM
Help overclocking i7 SEVEN Overclocking, Tweaking and Benchmarking 8 July 19, 2009 04:10 AM
Overclocking HELP please Crysisfan11 Overclocking, Tweaking and Benchmarking 1 May 27, 2009 10:15 AM
Needs some help overclocking lanken123 Overclocking, Tweaking and Benchmarking 0 April 21, 2009 11:51 AM
Need some help on Overclocking ShinseiKen CPU's and Motherboards 10 July 11, 2007 07:41 PM
